Uusin KodiDirect
Uusin KodiDirect Enigma2.
Hello Friends,
Post 1 of this thread will contain guidance on some user queries relating to the installation and use of KodiDirect.
More items will be added as we go along. I hope you will find these useful.
(1) Plugin KodiDirect Installation
(a) Normal installation on receivers with large flash memory
Ftp to folder /tmp - the attached plugin file :-
enigma2-plugin-extensions-kodidirect_3.1_r0_all.ipk
Then give telnet command :
opkg install /tmp/enigma2-plugin-extensions-kodidirect_3.1_r0_all.ipk
Restart enigma.
(b) Installation on receivers with small flash memory but with usb or hdd storage
Ftp to folder /tmp - the attached plugin file as appropriate :-
enigma2-plugin-extensions-kodidirect-usb_3.1_r0_all.ipk
or
enigma2-plugin-extensions-kodidirect-hdd_3.1_r0_all.ipk
opkg install enigma2-plugin-extensions-kodidirect-usb_3.1_r0_all.ipk
or
opkg install enigma2-plugin-extensions-kodidirect-hdd_3.1_r0_all.ipk
Restart enigma.
(2) KodiDirect Update
When there is a new update to KodiDirect- you will see a message to install. Select "Yes" and the addon will be installed. Press 'OK' when you see 'Execution finished' in the console message - then enigma will restart.
Any update will include all previous updates.
(3) Addons
To install addons - in first screen - select "Install addons".
There are 3 options which are obvious.
Tested Kodi addons are in the 'KodiDirect list' option.
Any other addons that work with Kodi on pc or elsewhere - may work directly with KodiDirect. You can test them by putting the .zip file in /tmp folder, /media/usb or /media/hdd.
Also addons can be tested directly from the Kodi official repos or any other repo - using the other options.
(4) Play m3u playlists
Install plugin.video.m3uplayer from KodiDirect list - IPTV.
Make a folder m3u in /etc/KodiDirect and put your m3u playlists in /etc/KodiDirect/m3u.
(4) Play Web Media (Video/Movies/IPTV) Links Directly
Install plugin.video.weblink and put your link urls in the Playlists folder. See the example lists in the addon.
The video links are mainly resolved via youtube-dl. From the youtube-dl supported sites you can find the video links. The supported sites are listed here :-
youtube-dl: Supported sites
For any web link that does not need resolving, for example live tv links, add playdirect- at the start of the name (see examples.txt).
Regards, pcd.
