kustijean
- vu+ duo 2
Black Hole 2.1.7 MultiBoot
WHAT IS NEW
WARNING: This Image has the latest drivers and CAN NOT be installed in multiboot. The image MUST be installed in flash.
Black Hole does not support images not installed in flash.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Button Red short press= access HbbTv functions
Button Red long press= Red Panel (Parallel Universes Teleportation)
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Online Black Hole image update
Manual Install BH packges (Manual installation of Black Hole packages)
Red Panel
BH Parallel Universe Teleportation
BlackHole
Avalon
Chaos
Ghost
Credits
Thanks to Pedro_Newbie for Backup script
Thanks to Littlesat and Pli Team for the original autolanguage and subtitle options code
DISCLAIMER
THE BLACK HOLE IMAGE IS BASED ON THE OFFICIAL FIRMWARE PUBLISHED BY VU+ AND IN ACCORDANCE WITH THE LAW IT CONTAINS ONLY SYSTEM ADDITIONS & GRAPHIC CHANGES.
THE BLACK HOLE IMAGE DOES NOT CONTAIN ANY EMULATOR, K E Y S, SOFTCAMS OR OTHER SYSTEM FOR VIEWING PAY - TV WITH OR WITHOUT A PAID SUBSCRIPTION.
LASTLY, THE BLACK HOLE IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.
LICENSE (TERM OF USE)
THE BLACK HOLE IMAGE IS ISSUED FOR THE FREE USE FOR ALL USERS PROVIDED THAT IT WILL NOT BE CHANGED IN ANY WAY AND THAT IT WILL ONLY BE USED FOR LAWFUL PURPOSES.
ANY CHANGES OR ADDITIONS TO BLACK HOLE IMAGE THAT INVOLVE UNLAWFUL USE OF THE IMAGE SUCH AS CARD-SHARING AND EMULATORS ARE NOT ALLOWED AND CAUSE THE REVOKE OF THIS LICENSE.
This is free hobbyist software and it comes with absolutely no warranty. Use it at your own risk.
WHAT IS NEW
- New switch from MeoBoot to OpenMultiBoot to use different kernels and drivers for each installed image.
- New skin MX i6p By Matrix10
- Vu+ drivers 20150623
- Fix tuning problem(AVL6211, duo2, solose)
- Improve vtuner(satip support)
- Fix scrambling bit in recording
- Improve transcoding
- Xbmc Support 576/720/1080 resolution
- Updated Vuplus-Blindscan
- Updated HbbTv
- Updated WebManual
- Added Sat>Ip Client
- Included UiPositionSetup
- Removed MeoBoot
- Added OpenMultiBoot
- Updated Lcd4Linux
- Updated MediaTree (usb tuners drivers)
- Fixed random socket error
- [ScanSetup] fixed error on complete scan with T2 tuners
- [ScanSetup] fixed TT3L10 automatic scan problem
- [unicable] support JESS(EN50607) and update unicable.xml
- AnimationSetup: set default to animations disabled
Addons
Infobar / OSD
Analog Clock Gui
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
UPnP Client Djmount
Pcsc Panel
Tuner Server
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
