XBMC Tuxbox Enigma Stream Client (Enigma Based Dreambox & Dbox2)
crashi
It's time for a progress announcement.
XBMC TuxBox Stream Client
The TuxBox Stream Client will only work with Enigma Based TuxBox images, this includes Dreambox and Dbox2.
Dbox2 Users with Neutrino Images: to use the XBMC TuxBox Client you must switch to a Enigma based images. I Recommend the PB-Enigma images from http://www.pb-powerboard.com/ or Enigma Based Images from other groups for the Dbox2.
How does it working:
you just create a share with the Tuxbox IP adress and login informations.
On Opening, the client will receive the Bouquet + Channel list.. and on select a channel , it will begin to stream... it will also display Current and Next Events. EPG, Recording and other usefull things and Information will be add. later.
The Share will be:
tuxbox://USER:pASSWORD@TUXBOX_IP:pORT/
Regards
GeminiServer
P.s.: if you want help me, i'm looking for a Sponsored Dreambox 7025.
http://www.xboxmediacenter.com/forum/showthread.php?t=23834
