VTi "Vu+ Team Image" - V 2.1 - 02.10.2010 OE 1.6
New VTi "Vu+ Team Image" - V 2.1 02.10.2010 OE 1.6
Enigma 29.09.2010
Treiber 27.09.2010
Plugins 29.09.2010
Skins 29.09.2010
Changes: VTi Bootlogos and new Radiomode Logo.
Multiple fixes at Imagesources and diffs, link from /usr/keys to /var/keys created and different litlle things in the image.
Vu+ Duo
Turn off LNB power at standby
Fix video event problem
Fix VFD display problem
Fix long press key problem
Adjust remote control response time a bit more
Fix virtual tuner problem.
Support Fancontorl interface at standby.(duo)
Support pcm sound(needs additional kernel modules)
in dolby digital downmix mode.
Clean up playback driver and fix misc. bugs.
Fix some diseqec switch problem.
Fix front rotary switch problem.(duo)
Separate gcc 4.4.3 version and 4.1.1 version
Make screen blank when zapping
Enhance tuning algorithm
Support more mkv file formats.
Fix occasional "no audio" problem in playback
Fix "late audio play" problem in playback
Support EOS detection in playback driver
Fix mp3 playback problem
Support FF trick mode in playback
Adjust memory allocation(Solo, needs a kernel update)
Support DTS Passthrough(Solo)
Fix vtuner frontend info
Fix tuning problem.(Solo)
From VTi Team
VTi Panel (Blue Button)
supported languages are Englisch, German, Dutch
short press on blue button opens VTi Panel, longer press opens Pluginmenu
Enhanced Multiboot support (BA and other)
Enhanced SATA-HDD recognition
Some Enigma2 fixes
Cronjobs full supported
No error massages while changeing the password
Pure audio disc playback - (USB CD Drive)
PowerControl systemplugin support
Kernel and system enhancements
OE1.6 QT-Webbrowser support
Many enhancements in network and networkbrowserplugin
Support for Windows 7 Samba (CIFS-Server)
Support for Vu+ Solo and Duo Imagebackup (USB/NFI-Restore) OE1.6 Fix
New Enigma2 Crashlogremover
Swapfile at /media/usb
IPK-Installer search at /media/usb/* too
Softwaremanager plugin is now build-in into the image
Rytec EPG
Fix FanControl settings problem after reboot
Some WLAN fixes
Settings in Fancontrol and Powercontrol must be identical!
Support for FTDI chipset cardreader like smargo and easymouse2
Greenscreen fix when no softcam is installed and any color key will be pressed
New Skin Infobar/Renderfile
Running Softcam shown in the Infobar
Better support for MyTube, MetacafeDirect and other
Download in der Database
HowTo ---> Flashen per USB Stick
Vu+ Duo The New Experience[/CENTER][/quote]
Enigma 29.09.2010
Treiber 27.09.2010
Plugins 29.09.2010
Skins 29.09.2010
Vu+ Duo
From VTi Team
Some Enigma2 fixes
Rytec EPG
Some WLAN fixes
