VIX Team Vu+ Duo Image - 05/09/2010
New VIX Image - v1.0
05/09/2010 - OE1.6
From VIX Team
Based on Official 5.2 Image
Enigma: 28.07.2010-vuplus_experimental.
Drivers: 27.08.2010.
GCC Version: 4.4.3.
Team VIX Enhancements
VIX Bootlogos and Radio Logo.
VIX Team Vu_HD+ Skin.
VIX Team softcam manager.
Cron jobs fully supported - Please restart the box to get the cron daemon running!
AutoTimer plugin integrated into image - Create an AutoTimer (Series Link), using Blue button in Current Channel EPG info.
CoolTV Plugin included in image, and modified to better embed with the image.
CCcam Info re-written for Image.
CCcam Info on Second Info Bar (Written specifically for the image to improve load times).
Swap Manager to create/use swap files on usb/hdd.
Modified Rytec EPG importer to work with OE 1.6*.
Image patched to allow EPG data to be loaded without the need for a restart**.
Recorded Items list modified to move item, browse directories. Works similarly to suomipoeka plugin. Can be selected to load via the recorded items button, or from the tv button.
Permanent Timeshift Plugin integrated (Disabled by default, turn on via Timeshift settings).
Integrated AutoTimer
Integrated VirtualZap
Integrated EPG Search
Integrated IMDb Search
* Pre-compiled epg.dat files can also be loaded with this plugin, but the rytec epg.dats can cause problems. So far in testing, satmate epg's seem fine.
**Uses version2 of the crossepg patch, and is compatible with crossepg.
Button Mappings
Short Red - Show current event info.
Long Red - Show current channel EPG info.
Short Green - Timers.
Long Green - AutoTimer Timers.
Short Yellow - EPG Search.
Long Yellow - IMDB Database.
Short Blue - Extensions.
Long Blue - Plugins Menu.
EPG - Opens the Cool TV EPG plugin
Known Bugs
Motor moving image does not display - Problem with main driver, reported to VU+.
Front VFD display showing the play button at the end of a video unless it is stopped manually - Problem with main driver, reported to VU+.
ECM time on second info bar in skin is not currently shown - New version of CCcam needed for OE1.6. (libgcc_s.so fix is unstable).
Installing other skins will cause the box to get into an infinite loop. Only use supported skins on this image (currently Vu_HD_Plus is the only supported skin)
Screenshots
Loading Screen:
Starting Enigma II Screen:
Radio Screen:
About:
Main Menu:
System Menu:
Plugins Main:
Plugins Download:
Softcam:
Softcam Setup:
Vu HD+ Main Menu:
Skin Setup:
Swap Manager:
Bouquets:
Program Guide:
EPG Grabber Setup:
CoolEPG:
CoolEPG Setup:
AutoTimer:
Recorded Files:
05/09/2010 - OE1.6
From VIX Team
GCC Version: 4.4.3.
Button Mappings
Known Bugs
Screenshots
Loading Screen:
Radio Screen:
About:
Main Menu:
System Menu:
Plugins Main:
Plugins Download:
Softcam:
Softcam Setup:
Vu HD+ Main Menu:
Skin Setup:
Swap Manager:
Bouquets:
Program Guide:
EPG Grabber Setup:
CoolEPG:
CoolEPG Setup:
AutoTimer:
Recorded Files:
