Vihdoin uusi ruDream 7000s
chaoscreator
Kemiönsaari
tämä pitää kokeilla, mydream ja monet muut hyvät imaget ovat pohjautuneet rudreamiin joten tätä kokeilen ja katson mikä on eli tämä pohjautuu 1.09.
ja taas harjoitellaan saksankieltä, eikö ole mukavaa.(EDIT .niin no tämä olikin tällä kertaa ehtaa englantia.)!?:
ruDream Image based on 1.09beta vom 10.03.2005
(Uploader: djmastera2000)
am: 11.03.2005 01:04
Beschreibung:
Welcome to ruDREAM image based on:
kernel v.2.6.9 (mod)
enigma v.109 (mod)
modules v.109 (expanded)
EMU & CARDREADER in image:
only official DreamCrypt camd
internet keyupdate
internet addonupdate
remember emu type for chanel and bouquet
Plugins:
EMUD v.1.22
EMUSET v.1.18
ADDONMANAGER v.2.02
SCRIPTSERVICE v.2.05
VIEWFILE v.1.00
HDPARM v5.2
HDDTERM v0.3-beta8
TuxCom v1.7
TuxTxt v1.83
SAMBA v1.9.18p8
CIFS (module for kernel)
ISOFS (built in a kernel)
ALL EMU (available to download)
OTHER ADDON (available to download)
Games:
TETRIS v.1.4
OTHER GAMES (available to download)
Change button funtion:
BLUE button - emuset
YELLO button - plugins list
AUDIO button - sound stream & mode select
TEXT button - video text
RED button - EPG List for current channel
RED button - double click for show EPG Style menu
Support:
h t t p ::/?allrussian.info/board.php?boardid=49
h t t p ://rudream.dvb.lv
irc channel #dbox2 or #rudream (dalnet servers)
Special thx to all guys and teams who help us do our image more powerful and stable:
kindzadza, mixvt, lucgas, vhunter, pnk66, puh, xphile, sphinx, Tom0000, mad*spike, mizu, jirka, FvS, komi
ruDbox Team, DBNA Team, xxx Team, The Hydra Team
When you like our work and would like to support it,
you can make a ******** using the Paypal button below. Every ******** helps,
even when it's $1,00!
h-t-t-p://rudream.dvb.lv/******/
or
h t t p ://www.webmoney.ru/:
RUB: 42301810800180190044
USD: 42301840400180190045
EUR: 42301978700180231246
Compiled by:
ruDREAM team
ChangeLog & notes:
11-03-2005:
- fix dot phantom in service selector
10-03-2005:
- fix crash enigma, after use textinput for scripservice
09-03-2005:
- fix many small bug, after updating with cvs
09-03-2005:
- small fix
- cvs update [09-03-2005]
08-03-2005:
- added suport check stable work newcamd
07-03-2005:
- added suport in EMUD run cardspider, for enable run cardspider create file:
echo cardspider >/tmp/cardspider
and hot reboot dreambox
- fix small many bug ADDONMANAGER
- fix window closing if in bouquet select dialog for setting EMU press button Lame
- fix the break of installation and closing of a window if in dialogue for uninstall
of language press button Lame
06-03-2005:
- added camd3n info
- fix closing a window if in dialogue of a choice of a source for installation of
expansion press button Lame
05-03-2005:
- adeed Syslog Setup
- fix bug EMUD
- fix small other bug
03-03-2005:
- fix bug format USB-stick
- added ability save current config and all settings to main flash
02-03-2005:
- small fix EMUD
28-02-2005:
- added opportunity to specify the link to a file or only
a way is if the name of a file xml by default will be used
(ex: h-t-t-p://domain.com/addons.xml or h-t-t-p://domain.com/)
file xml by default: addon_xxxxxxxxxxxxxxxx.xml, where
xxxxxxxxxxxxxxxx - number version image
- added output loginfo on syslogd for emud
- fix bug EMUD (crash enigma at change EMU)
27-02-2005:
- added output loginfo on syslogd, for enable run command:
syslogd -R xxx.xxx.xxx.xxx (xxx.xxx.xxx.xxx - IP addres you PC)
- fix bug compiling emuset
- fix other bug
26-02-2005:
- added new serviceselector in file mode:
[multy red button]-[Movie]-[Music]-[Photo]
added the predetermined folders for music and photo:
/hdd/music ; /hdd/photo
- added ability setting of function of the red button of
the selectorservices in file mode:
[Root]-[Playlist]-[Bouquets]
- added setup serviceselector function red button in expert setup menu
- added setup EPG style in expert setup menu
- cvs update [26-02-2005]
25-02-2005:
- fix alternative links for addons.xml
- small fix emud and other bug
- added setup slide show in expert setup menu
- added ability set alternative links for images.xml
- mod kernel for supporting more USB-sthick
- added pause update EPG and kill all EMU at flashing image
- fix purpose of buttons for web interface (yello and blue)
- fix pic in help for enigmaMain
18-02-2005:
- fix enigma crashing if pressing OK on splitsize item in Expert Setup
- cvs update [12-02-2005]
- now use dreambox tag form cvs, enigma as always from head tag
09-02-2005:
- fix drivers color swaping
- fix busybox killall, now must work with flashwizzard
- add ability set alternative links for addons.xml
- add ability don't hide infobar in Radio and MP3 mode look in Infobar Setup
- cvs update [09-02-2005]
22-11-2004:
- add decryption dish network epg, thx DBNA team
- fix valign for NTSC mode
- cvs update [22-11-2004]
12-11-2004:
- small fix emud (work with new mgcamd)
- cvs update [12-11-2004]
NOTES:
(*) available manual installation and loading through the menu
(**) available manual installation
md5: ec81fd58f8acd1a6af2cf3113aa193bc
Kb: 5911
Löydät ainakin täältä:
