Viasat EGP kuntoon.
elmo
Viasat EGP kuntoon.
Kukakohan jaksaisi/viitsisi koodata Viasat:n EGP kuntoon?
Aikaani etsittyäni, löysin Viasat:n "pitkän" EGP listan.
Löytyy mm TP:stä (12054.00 V), pid:llä 57 (0x0039)
Vakoilla sitä voi, esim. dvbsnoop -n 100 -crc -nph 0x0039 komennolla
=== CLIP ===
Event_ID: 972 (0x03cc)
Start_time: 0xd66a141000 [= 2009-02-28 14:10:00 (UTC)]
Duration: 0x0002000 [= 00:20:00 (UTC)]
Running_status: 0 (0x00) [= undefined]
Free_CA_mode: 1 (0x01) [= streams [partially] CA controlled]
Descriptors_loop_length: 311 (0x137)
DVB-DescriptorTag: 77 (0x4d) [= short_event_descriptor]
descriptor_length: 36 (0x24)
ISO639_2_language_code: dan
event_name_length: 20 (0x14)
event_name: "Kejserens nye skole" -- Charset: Latin alphabet no. 5
text_length: 11 (0x0b)
text_char: "Tegnefilm." -- Charset: Latin alphabet no. 5
descriptor_length: 45 (0x2d)
ISO639_2_language_code: fin
event_name: "Keisarin uusi koulu" -- Charset: Latin alphabet no. 5
text_length: 20 (0x14)
text_char: "Keisarin uusi koulu" -- Charset: Latin alphabet no. 5
descriptor_length: 97 (0x61)
ISO639_2_language_code: nor
event_name: "Kejsarens nya skola" -- Charset: Latin alphabet no. 5
text_length: 72 (0x48)
text_char: "Baserad på filmen Kejsarens nya stil kommer nu denna animerade serie. ." -- Charset: Latin alphabet no. 5
ISO639_2_language_code: swe
DVB-DescriptorTag: 85 (0x55) [= parental_rating_descriptor]
descriptor_length: 16 (0x10)
Country_code: SWE
Rating: 0 (0x00) [= undefined]
Country_code: NOR
Country_code: DNK
Country_code: FIN
DVB-DescriptorTag: 95 (0x5f) [= private_data_specifier_descriptor]
descriptor_length: 4 (0x04)
PrivateDataSpecifier: 24577 (0x00006001) [= NDC 1 - 6]
DVB-DescriptorTag: 84 (0x54) [= content_descriptor]
descriptor_length: 2 (0x02)
Content_nibble_level_1: 5 (0x05)
Content_nibble_level_2: 0 (0x00)
[= childrens's/youth program (general)]
User_nibble_1: 0 (0x00)
User_nibble_2: 0 (0x00)
root@dm800:~# dvbsnoop -s pidscan -pd 6
dvbsnoop V1.4.51 -- http://dvbsnoop.sourceforge.net/
Transponder PID-Scan...
PID found: 0 (0x0000) [SECTION: Program Association Table (PAT)]
PID found: 1 (0x0001) [SECTION: Conditional Access Table (CAT)]
PID found: 16 (0x0010) [SECTION: Network Information Table (NIT) - actual network]
PID found: 17 (0x0011) [SECTION: Service Description Table (SDT) - other transport stream]
PID found: 18 (0x0012) [SECTION: Event Information Table (EIT) - other transport stream, present/following]
PID found: 20 (0x0014) [SECTION: Time Date Table (TDT)]
PID found: 33 (0x0021) [SECTION: User private]
PID found: 52 (0x0034) [SECTION: User private]
PID found: 56 (0x0038) [SECTION: Service Description Table (SDT) - other transport stream]
PID found: 57 (0x0039) [SECTION: Event Information Table (EIT) - other transport stream, schedule]
PID found: 58 (0x003a) [SECTION: Service Description Table (SDT) - other transport stream]
PID found: 82 (0x0052) [SECTION: ATSC reserved]
PID found: 85 (0x0055) [SECTION: User private]
PID found: 86 (0x0056) [SECTION: Program Map Table (PMT)]
PID found: 150 (0x0096) [SECTION: DVB CA message section (EMM/ECM)]
PID found: 151 (0x0097) [SECTION: DVB CA message section (EMM/ECM)]
PID found: 152 (0x0098) [SECTION: DVB CA message section (EMM/ECM)]
PID found: 161 (0x00a1) [SECTION: DVB CA message section (EMM/ECM)]
PID found: 162 (0x00a2) [SECTION: DVB CA message section (EMM/ECM)]
PID found: 163 (0x00a3) [SECTION: DVB CA message section (EMM/ECM)]
PID found: 164 (0x00a4) [SECTION: DVB CA message section (EMM/ECM)]
PID found: 166 (0x00a6) [SECTION: DVB CA message section (EMM/ECM)]
PID found: 168 (0x00a8) [SECTION: DVB CA message section (EMM/ECM)]
PID found: 192 (0x00c0) [SECTION: DVB CA message section (EMM/ECM)]
PID found: 193 (0x00c1) [SECTION: DVB CA message section (EMM/ECM)]
PID found: 933 (0x03a5) [SECTION: Program Map Table (PMT)]
PID found: 1100 (0x044c) [SECTION: Program Map Table (PMT)]
PID found: 1101 (0x044d) [scrambled]
PID found: 1102 (0x044e) [scrambled]
PID found: 1106 (0x0452) [PS/PES: private_stream_1]
PID found: 1107 (0x0453) [SECTION: DVB CA message section (EMM/ECM)]
PID found: 1110 (0x0456) [SECTION: Program Map Table (PMT)]
PID found: 1111 (0x0457) [scrambled]
PID found: 1112 (0x0458) [scrambled]
PID found: 1116 (0x045c) [PS/PES: private_stream_1]
PID found: 1117 (0x045d) [SECTION: DVB CA message section (EMM/ECM)]
PID found: 1120 (0x0460) [SECTION: Program Map Table (PMT)]
PID found: 1121 (0x0461) [scrambled]
PID found: 1122 (0x0462) [scrambled]
PID found: 1126 (0x0466) [PS/PES: private_stream_1]
PID found: 1127 (0x0467) [SECTION: DVB CA message section (EMM/ECM)]
PID found: 1130 (0x046a) [SECTION: Program Map Table (PMT)]
PID found: 1131 (0x046b) [scrambled]
PID found: 1132 (0x046c) [scrambled]
PID found: 1133 (0x046d) [scrambled]
PID found: 1134 (0x046e) [scrambled]
PID found: 1135 (0x046f) [scrambled]
PID found: 1136 (0x0470) [PS/PES: private_stream_1]
PID found: 1139 (0x0473) [SECTION: DVB CA message section (EMM/ECM)]
PID found: 1140 (0x0474) [SECTION: Program Map Table (PMT)]
PID found: 1141 (0x0475) [scrambled]
PID found: 1142 (0x0476) [scrambled]
PID found: 1143 (0x0477) [scrambled]
PID found: 1144 (0x0478) [scrambled]
PID found: 1145 (0x0479) [scrambled]
PID found: 1146 (0x047a) [PS/PES: private_stream_1]
PID found: 1147 (0x047b) [PS/PES: private_stream_1]
PID found: 1148 (0x047c) [SECTION: DVB CA message section (EMM/ECM)]
PID found: 1149 (0x047d) [SECTION: Program Map Table (PMT)]
PID found: 1150 (0x047e) [SECTION: Program Map Table (PMT)]
PID found: 1151 (0x047f) [PS/PES: ITU-T Rec. H.262 | ISO/IEC 13818-2 or ISO/IEC 11172-2 video stream]
PID found: 1152 (0x0480) [PS/PES: ISO/IEC 13818-3 or ISO/IEC 11172-3 audio stream]
PID found: 1153 (0x0481) [PS/PES: ISO/IEC 13818-3 or ISO/IEC 11172-3 audio stream]
PID found: 1154 (0x0482) [PS/PES: ISO/IEC 13818-3 or ISO/IEC 11172-3 audio stream]
PID found: 1155 (0x0483) [PS/PES: ISO/IEC 13818-3 or ISO/IEC 11172-3 audio stream]
PID found: 1156 (0x0484) [PS/PES: private_stream_1]
PID found: 1157 (0x0485) [PS/PES: private_stream_1]
PID found: 1158 (0x0486) [SECTION: DVB CA message section (EMM/ECM)]
PID found: 1159 (0x0487) [SECTION: Program Map Table (PMT)]
PID found: 1160 (0x0488) [SECTION: Program Map Table (PMT)]
PID found: 1161 (0x0489) [scrambled]
PID found: 1162 (0x048a) [scrambled]
PID found: 1165 (0x048d) [SECTION: DVB CA message section (EMM/ECM)]
PID found: 1166 (0x048e) [PS/PES: private_stream_1]
PID found: 1170 (0x0492) [SECTION: Program Map Table (PMT)]
PID found: 1171 (0x0493) [scrambled]
PID found: 1172 (0x0494) [scrambled]
PID found: 1173 (0x0495) [scrambled]
PID found: 1174 (0x0496) [scrambled]
PID found: 1175 (0x0497) [scrambled]
PID found: 1179 (0x049b) [SECTION: DVB CA message section (EMM/ECM)]
PID found: 1180 (0x049c) [SECTION: Program Map Table (PMT)]
PID found: 1182 (0x049e) [SECTION: Program Map Table (PMT)]
PID found: 1183 (0x049f) [SECTION: User private]
PID found: 1184 (0x04a0) [SECTION: Program Map Table (PMT)]
PID found: 1185 (0x04a1) [SECTION: User private]
PID found: 1186 (0x04a2) [SECTION: Program Map Table (PMT)]
PID found: 1187 (0x04a3) [SECTION: User private]
PID found: 1190 (0x04a6) [SECTION: Program Map Table (PMT)]
PID found: 1191 (0x04a7) [SECTION: DVB CA message section (EMM/ECM)]
PID found: 1195 (0x04ab) [SECTION: Program Map Table (PMT)]
PID found: 1196 (0x04ac) [SECTION: DVB CA message section (EMM/ECM)]
PID found: 1210 (0x04ba) [SECTION: Program Map Table (PMT)]
PID found: 1211 (0x04bb) [scrambled]
PID found: 1212 (0x04bc) [SECTION: Program Map Table (PMT)]
PID found: 1213 (0x04bd) [scrambled]
PID found: 2300 (0x08fc) [SECTION: DVB CA message section (EMM/ECM)]
root@dm800:~#
Micci
Raisio
T90 + UHF + VHF
Duo2 (T2+S2), Uno (T2)
CKN
Samsung 55", Gigablue Hd quad. Buffalo verkkoasema.
