Uusin Dreamset (kanavalistaeditori kaikille Enigma2 boxeille)
Dreamset is a settings editor for digital satellite receivers running Enigma 1, Enigma 2 and Neutrino Plus firmwares like DreamBox. Triple Dragon receivers are also supported.
You can use Dreamset to edit Settings of the following formats:
# Enigma-1
# Enigma-2(Satellite/Cable/Terrestrial)
# Neutrino NPlus
# Triple Dragon
Also Dreamset can open and import settings of the following formats:
# DGStation/Relook 200s/400s (dat)
# Nokia 9800s/9902s Files (m98)
# LyngSat script files (dat)
# SatcoDx(sdx)
# DVB (dvb)
# Humax (hnf)
Dreamset offers a user friendly interface with a plethora of usefull operations which make settings modification easier.
# Add,Change,Delete bouquets and favorite lists
# Reorganize services in bouquets and favorite lists
# Add,Change,Delete services,transponders,satellites
# Flexible User Interface, multiple selection and Drag & Drop.
# User defined Sorting of services in a list/bouquet and other sorting operations
# Multilanguage support for names(Unicode Support).
# Markers support.
# Clipboard Copy/Paste of lists,services,channels,transponders (you can copy.paste from one Dreamset to another)
# Import Favorite Lists from other settings like DreamBox,Nokia 9800,Humax.
# Convert settings to other supported formats.
# Multilanguage User Interface support.
# DreamBox configuration editor (advanced).
# Custom telnet and http commands
# Dreamset can minimized to tray, right cklick to Dreamset Icon popups a menu with basic operations
# Multibox Configuration, you can define more then one box and switch between them at once.
# Signal monitor and DiseqC motor control from dreamset (dreambox plugin is installed in your box) only for Enigma 1 and Neutrino
29/08/2008 - ver 2.17
Fixed: KingOfSat, parsing list names
Added: KingOfSat, download dialog allows to change the satellite order which the services will be appeard in the lists
Added: KingofSat, the order and the selected for download satellites are stored to registry
Added: KingofSat, multilple markers Satelite/Provider in generated lists
Added: Service sort dialog allows markers in all sorting levels.
Added: Read Enigma2 ver 4 settings, write support will be added later when new format will be the final
timoj
timoj
timoj
Lumikki
Länsi Kanta-Häme
Vu+ SoloSE (2xT2) OA 5.1
NUC5+ Kodi (18.8) Libre
RPi3B+ Kodi (18.9) Libre
LG C9 65" & Sam. LCD 40"
AV Yamaha RX-V375
Proson 5.1
