hms
The Gemini2 Project 3.80 DM800
http://www.i-have-a-dreambox.com/wbb2/thread.php?threadid=95860
Gemini2 v3.8:
* Engima from: 26.09.2008
* Busybox 1.0.1
* Tuxtxt 1.95
* long BLUE -> PiP (DM7025)
* RED - Record
* Yellow - Timeshift
Addons:
Camd:
* Assign different Camds to Stations/Providers (AutoCam).
Daemon / Server / Clients:
* Upnp Server / Client
Infobar / OSD:
* Provider and Satellite will be shown in the Infobar (depending on the skin).
* Show Onlinestatus when the Box is connected to the Internet (has to be activated in the BP -> Extras/Settings/Online)
* HDTV-Logo in the Infobar (DM80..)
Files / Devices:
* Device Manager (format, mount and other functions)
* Hotplug for USB-Devices (are shown in the OSD - Can be mounted using the Device-Manager)
EPG:
* EPG-autosave- Saves the EPG data at a defined time
* Duration of current Event in the programm overview ( BP -> Info -> EPG)
Extra:
* Dreamnetcast (shoutcast-player) with Streamripper (direct recording from server and coding into mp3s).
* Alarm clock(plays mp3s at a fixed time)
* System Info: Many extra receiver infos like stream-rates, kernel-, memory- and processinfos.
* EPG Cache and EPG Refresh (updates the EPG at the night) adjustable over BP.
* overview of the different Scrambling systems that the current station uses.
* Quickbutton
* Summary of the HDTV-Channels in the Channellist->Satellites (DM80..)
* HD-Skin preinstalled
* Many (partly internal) changes,that make it possible, to skin all menus completely
Fix + Updates:
* RSS-Reader
* Weather Plugin
* Mount overview now with icons
* see CVS
and won't be supported.
Download via Database
Gemini2 v3.8:
* Busybox 1.0.1
* Tuxtxt 1.95
* RED - Record
Addons:
Camd:
Infobar / OSD:
Files / Devices:
EPG:
Extra:
* Quickbutton
Fix + Updates:
* RSS-Reader
* Weather Plugin
* see CVS
