The Gemini2 Project 3.70 DM7025
Gemini2 v3.7:
* Engima from: 22.07.2008
* Busybox 1.0.1
* Tuxtxt 1.95
* long BLUE -> PiP (DM7025)
* RED - Record
* Yellow - Timeshift
Addons:
Camd:
Daemon / Server / Clients:
* Upnp Server / Client
Infobar / OSD:
* Show Onlinestatus when the Box is connected to the Internet (must be activated in the BP -> Extras/Settings/Online)
* HDTV-Logo in the Infobar (DM80..)
Files / Devices:
* Device Manager is still beta (format, mount and other functions)
EPG:
* EPG-autosave- Saves the EPG data in a defined time
* Duration of current Event in the programm overview ( BP -> Info -> EPG)
Extra:
* overwiev of the different Cryptingsystems which the actual station uses.
* Quickbutton
* Summary of the HDTV-Channels in the Channellist->Satellites (DM80..)
* BP-Menu with new optic
* Hotplug for USB-Devices (are shown in the OSD - Can be mount using the Device-Manager)
Fix + Updates:
* Stream-Traffic and HDD-Temperature
* see CVS
and won't be supported!
Micci
Raisio
T90 + UHF + VHF
Duo2 (T2+S2), Uno (T2)
Micci
Raisio
T90 + UHF + VHF
Micci
Raisio
T90 + UHF + VHF
timoj
