The Gemini2 Project 3.40 DM7025
justiina
montenegro
Gemini2 v3.4:
* Engima from: 24.04.2008
* GCC 4.1.1 Original CVS
* Kernel 2.6.12.6
* Busybox 1.0.1
* Tuxtxt 1.95
* CIFS 1.44
* long BLUE -> PiP
* RED - Record
* Yellow - Timeshift
Addons:
* Downloading and installation of additional features via internet from Gemini server.
Camd:
Daemon / Server / Clients:
* Upnp Server / Client
Infobar / OSD:
* Showing Onlinestatus when the Box is connected to the Internet (must be activated in the BP -> Extras/Settings/Online)
Files / Devices:
* Support for CDROM/DVD no matter ift it is IDE ur USB
Extra:
* Password can be changed over the menu.
* overwiev of the different Cryptingsystems the actual station uses.
* Quickbutton
* Turning of images, also automatically by EXIF data.
* File browser revised, 2 additional features and optics.
* EPG Auto Save, save the EPG on a fixed time.
* EPG additional info (BP-> info).
* New standard - Skin
* ReZapp, Switch back to a channel on a fixed time (BP-> Extra-> ReZapp).
* Moving the infobar now optical solved.
Fix + Updates:
* Fix from @lexx911 for VLC-Streaming.
* see CVS
and won't be supported!
Download via Database
tappari
Vantaa
Antenniverkko:
Duo2
Duo 4K SE
Uno 4K SE
Ultimo 4K
Satelliitti:
Ultimo 4K
tappari
Vantaa
Antenniverkko:
Duo2
Duo 4K SE
Uno 4K SE
Ultimo 4K
Satelliitti:
Ultimo 4K
tappari
Vantaa
Antenniverkko:
Duo2
Duo 4K SE
Uno 4K SE
Ultimo 4K
Satelliitti:
Ultimo 4K
tappari
Vantaa
Antenniverkko:
Duo2
Duo 4K SE
Uno 4K SE
Ultimo 4K
Satelliitti:
Ultimo 4K
timoj
tappari
Vantaa
Antenniverkko:
Duo2
Duo 4K SE
Uno 4K SE
Ultimo 4K
Satelliitti:
Ultimo 4K
timoj
