The Gemini2 Project 3.30 DM7025
Gemini2 v3.3:
* Engima from: 04.02.2008
* GCC 4.1.1 Original CVS
* Kernel 2.6.12.6
* Busybox 1.0.1
* Tuxtxt 1.95
* CIFS 1.44
* long BLUE -> PiP
* RED - Record
* Yellow - Timeshift
Addons:
* Downloading and installation of additional features via internet from Gemini server.
Camd:
Daemon / Server / Clients:
* Upnp Server / Client
Infobar / OSD:
* Showing Onlinestatus when the Box is connected to the Internet (must be activated in the BP -> Extras/Settings/Online)
Files / Devices:
* Support for CDROM/DVD no matter ift it is IDE ur USB
Extra:
* Password can be changed over the menu.
* overwiev of the different Cryptingsystems the actual station uses.
* Quickbutton
* Services/Daemons summarised
* RSS/Weather Plugin you can create your own country specific "wetter.xml"
* Dreamnetcast with Favorites-administration
Fix + Updates:
* Routines in RSS-Reader
* changes in our MP3-Routines (problems with simultaneously usage of the Alarm clock, Dreamnetcast and eMail-Checker solved)
* eMail-Checker and IMAP (Unread mail remain unread, problems with GMail solved)
* see CVS
and won't be supported!
Micci
Raisio
T90 + UHF + VHF
Duo2 (T2+S2), Uno (T2)
Micci
Raisio
T90 + UHF + VHF
Micci
Raisio
T90 + UHF + VHF
timoj
Micci
Raisio
T90 + UHF + VHF
Micci
Raisio
T90 + UHF + VHF
timoj
Micci
Raisio
T90 + UHF + VHF
timoj
timoj
