The Gemini2 Project 2.40 DM7025
chaoscreator
Kemiönsaari
Löytyy täältä:
Speksit:
Gemini2 v2.40:
* Engima from: 31.05.2007
* GCC 4.1.1 Original CVS
* Kernel 2.6.12.6
* Busybox 1.0.1
* Tuxtxt 1.95
* CIFS 1.44
* long BLUE -> PiP
* RED - Record
* GREEN - Subservices
* Yellow - Timeshift
Addons:
* Downloading and installation of additional features via internet from Gemini server.
Camd:
Daemon / Server / Clients:
* Upnp Server / Client
Infobar / OSD:
Files / Devices:
* Support for CDROM/DVD.
Extra:
* Password can be changed over the menu.
* Showing Onlinestatus when the Box is connected to the Internet (must be activated in the BP -> Extras/Settings/Online)
* Spinner (response time adjustable of 0,5 to 2 sec. and deactivate).
Fix + Updates:
* see CVS
and won't be supported.
Download via Database
Micci
Raisio
T90 + UHF + VHF
Duo2 (T2+S2), Uno (T2)
