The Gemini2 Project 2.30 DM7025
tequ69
Tattarinharju
Gemini2 v2.30:
* Engima from: 19.04.07
* GCC 4.1.1 Original CVS
* Busybox 1.0.1
* Kernel 2.6.12.6
* RED - Record
* GREEN - Subservices
* Display of CaIDs via Infobar
* Password can be changed via menu
* Autocamd
* camd scricpt can be edited
* HDD performance
* Weather Plugin with 10 days forecast
* RSS/RDF reader with TOP list from RSS-scout
* Active PiP
* Blue Button with following functions: 1 x (short) Blue Panel, 2 x (short) Blue Panel -> Extras/Settings, 1 x (long) blue PiP
* The image does now contain a useraddon.xml in /etc to enter an own addon server which will additionally be displayed in download menu. The file actually contains a example.
* Nemesis skins
* IPK can be choosen and installed via browser
* Installation of plugins without Enigma restart
* Picon integrated in Gemini (the PNG file must have the same name as the channel) -> Installation of Pic-Icons via Blue Panel
* True automount, examples in /etc/automount.conf. Devices, NFS or CIFS get mounted automatically and also erased if they are not in use for longer than 2 minutes (only working if the kernel of Gemini is in use, config via Blue Panel)
* Dreamnetcast
* PictureViewer from CVS
* Webcam
* real flashing clock when recording in standby
* Dreamnetcast and Streamripper (direct recording from server and coding into mp3´s)
* Webcam-Viewer extended (FullScreen mode - settings will be saved)
* EPG Refresh
* Upnp Server / Client
* Dropbear (ssh) can now be tourned on/off
* Dreamnetcast now with bitrate filter (24..256)
* fuse update from 2.6.1 to 2.6.3
* libupnp update from 1.4.1 to 1.4.3
* ushare update from 0.9.8 to 0.9.10
* streamripper update from 1.61.3 to 1.61.27
Fix + Updates:
* see CVS
* UPnP: files with "umlauts" (special characters) are now displayed; full *.ts support from the UPnP Server
and won't be supported!
Download via Database
crashi
  • infobar.tar.gz
    28.5 KB · Lukukerrat: 10
