The Gemini2 Project 1.50 (7025)
crashi
Gemini2 v1.50:
* Enigma from: 16.05.2006
* GCC 3.4.5 Original CVS
* Busybox 1.01
* Kernel 2.6.12.6
* RED - Record
* GREEN - Subservices
* Displaying CaID´s in the Infobar
* Change the password out from menu
* Autocamd
* camd script can be edited
* Hdd-Performance
Fix:
* camd user name was not indicated
* The reminder doesn´t work if the event occours on the 1th
* satellites.xml only approx. 140kb were created
Attention:
* Do not use old Gemini2 skins!
and won't be supported!
http://www.i-have-a-dreambox.com/wbb2/database.php
