chaoscreator
- Kemiönsaari
The Gemini Project 3.60 DM7000
Esim. täältä:
Speksit:
Gemini v3.60:
* Enigma of: 31.05.2007
* GCC 3.4.4 Original CVS
* Web Interface: 6.0.2-Expert
* Busybox 1.01
* Tuxtxt V1.99
* CIFS 1.44
Remotecontrol:
* 2x RED - EPG style menu
* GREEN - subservices
Addons:
Camd:
Daemon / Server / Clients:
Files / Devices
* Support for OGG/Vorbis
* Backup function
Extras:
Fix + update:
* see CVS
nterfaces WebIF:
Recommendation:
Download via Database
Esim. täältä:
Speksit:
Gemini v3.60:
* Busybox 1.01
* Tuxtxt V1.99
* CIFS 1.44
Remotecontrol:
Addons:
Camd:
Files / Devices
* Backup function
Extras:
Fix + update:
* see CVS
nterfaces WebIF:
Recommendation:
