The Gemini Project 3.20 DM7020
Gemini v3.20
* Enigma of: 12.10.2006
* GCC 3.4.4 Original CVS
* Web Interface: 5.9.7-Expert
* Busybox 1.2.1
* Tuxtxt V1.99
Function Buttons:* BLUE - Blue Panel (BP)
* 2x RED - EPG style menu
* GREEN - subservices
* Cam settings: For example emu renaming,
multichannel patch switchable ( >=7000 )
* Download and installation of additional features
via Internet from Gemini server
* System Info: Many extra box infos (for example
harddisk-temperature or all Enigma settings)
* JPEGs can be rotated and the EXIF tags can be
displayed ( >=7000 )
* Support for OGG/Vorbis
* Quick-Button-Menu: Many extra features for the
yellow button
* smbmount
* Support for CDROM/DVD, no matter if IDE or USB
(>=7000 )
* Record CIFS/NFS: Record to a CIFS or NFS mounted
harddisk (only working without internal hard
drive, mountpoint set to "var/mnt/hdd" and at
least 3GB disk space)
* Extra menu: Settings for many features like
Inadyn, HTTPD, EPG-Cache, "/var" swap-out and many
more
* Backup function
* Background pictures for Radio, MP3 and SCAN can
be changed via Blue Panel
* Calender including reminder (can be changed via
.../calendar.conf)
* MVI's can be converted and tested (from JPG,
BMP, GIF or PNG)
* EPG for Dishnetwork
* 2 new root entries for music and pictures can be
created in the filemenu
(BP->Extras/Settings->Root-Entry)
(BP->Extras/Settings->Printer (LPD), FAQ can be
found in the database
* Alarm clock with volume offset adjustable
playing your own WAV-files.
(>=7000)
* cifs-1.42b
* Multisocket second camd socket (cam1.socket)
switchable.
* Register an own addon server (useraddon.xml)
* Provider, Frequency, symbol rate and FEC
displayed on infobar (dependent on skin)
* Picon integrated in Gemini (the PNG file must
have the same name as the channel) -> Installation
of Picicons via Blue Panel
* True automount, examples in
var/etc/automount.conf. Devices get mounted
automatically and also erased if they are not in
use for longer than 2 minutes (only working if the
kernel of Gemini 3.1 is in use)
NEW:
* automount.conf - can be edited using the Blue Panel
* Menu for recordings in the WebIF and Blue Panel, where before and after record time and the location can be changed.
* dropbear now active in all images (ssh - deamon)
* "http authentification" can now be separately activated/deactivated for the message box
* added the possibilty to have the infobar permantly active in radio mode
* now everything can be displayed in the extra field, when supported by the skin.
Fix + Update:
* attend CVS
* cifs-1.44
* Busybox 1.2.1
Interfaces WebIF:
http://127.0.0.1/cgi-bin/StopCam?ZAHL (ZAHL =
number of cam)
http://127.0.0.1/cgi-bin/StartCam?ZAHL (ZAHL =
number of cam)
We'd like to thank everybody who paricipated in
the "Gemini suggestion" thread. Unfortunatly many
things can not be realized from our side.
and won't be supported!
Recommendation:
If you don't install the Image in flash memory,
the flash image shouldn't be of a old version. A
swap file/partition (>= 16MB) should be present
http://www.i-have-a-dreambox.com/
