- 3 * Nvidia Shield + Synology NAS DS218+ LG 77CX6LA + Genelec + RasPi/rAudio + Adam T5V + T7V + T10S - ArcoLinux
The Gemini Project 3.20 DM500 MaxVar
Gemini v3.20:
* Enigma of: 12.10.2006
* Web Interface: 5.9.7-Expert
* Busybox 1.2.1
* Tuxtxt V1.99
Attention!
This MaxVar Image is only running in flash (it has been only tested that way). Please do only use DreamUp and don´t forget the flash erase. Do not use other tools like FW or DCC.
* Own addon server via internet.
* AutoCam: Emu can be linked to channels/provider
* Cam settings: For example emu renaming,
multichannel patch switchable ( >=7000 )
* OSD: EMM- and ECM- Display switchable
* Download and installation of additional features
via Internet from Gemini server
* System Info: Many extra box infos (for example
harddisk-temperature or all Enigma settings)
* Gemini news loaded in background
* JPEGs can be rotated and the EXIF tags can be
displayed ( >=7000 )
* Quick-Button-Menu: Many extra features for the
yellow button
* smbmount
* Support for CDROM/DVD, no matter if IDE or USB
(>=7000 )
* Record CIFS/NFS: Record to a CIFS or NFS mounted
harddisk (only working without internal hard
drive, mountpoint set to "var/mnt/hdd" and at
least 3GB disk space)
* Extra menu: Settings for many features like
Inadyn, HTTPD, EPG-Cache, "/var" swap-out and many
more
* Dreamnetcast: inclusive Shoutcast TOP(100)
* Background pictures for Radio, MP3 and SCAN can
be changed via Blue Panel
* Own scripts can be started via Blue Panel
* Calender including reminder (can be changed via
./calendar.conf)
* MVI's can be converted and tested (from JPG,
BMP, GIF or PNG)
* Bootlogo for 7020 can be changed via menu
* New font and libfribidi for arabic language
* EPG for Dishnetwork
* 2 new root entries for music and pictures can be
created in the filemenu
(BP->Extras/Settings->Root-Entry)
* Create your own Satellites.xml
* Dreambox can be used as printserver
(BP->Extras/Settings->Printer (LPD), FAQ can be
found in the database
* Alarm clock with volume offset adjustable
playing your own WAV-files.
* Display of current channel stream rates
(>=7000)
* cifs-1.42b
* Multisocket second camd socket (cam1.socket)
switchable.
* Register an own addon server (useraddon.xml)
* Provider, Frequency, symbol rate and FEC
displayed on infobar (dependent on skin)
* Picon integrated in Gemini (the PNG file must
have the same name as the channel) -> Installation
of Picicons via Blue Panel
* True automount, examples in
var/etc/automount.conf. Devices get mounted
automatically and also erased if they are not in
use for longer than 2 minutes (only working if the
kernel of Gemini 3.1 is in use)
* Installation of addons via browser
NEW:
* automount.conf - can be edited using the Blue Panel
* Menu for recordings in the WebIF and Blue Panel, where before and after record time and the location can be changed.
* dropbear now active in all images (ssh - deamon)
* "http authentification" can now be separately activated/deactivated for the message box
* added the possibilty to have the infobar permantly active in radio mode
* now everything can be displayed in the extra field, when supported by the skin.
Fix + Update:
* attend CVS
* cifs-1.44
* Busybox 1.2.1
Interfaces WebIF:
http://127.0.0.1/cgi-bin/StopCam?ZAHL (ZAHL =
number of cam)
http://127.0.0.1/cgi-bin/StartCam?ZAHL (ZAHL =
number of cam)
We'd like to thank everybody who paricipated in
the "Gemini suggestion" thread. Unfortunatly many
things can not be realized from our side.
This images doesn't contain any keys or softcams.
Backups or other modified Images are not from us
and won't be supported!
If you don't install the Image in flash memory,
the flash image shouldn't be of a old version. A
swap file/partition (>= 16MB) should be present
if several processes running in background.
Download soon on http://www.dreamboxworld.com/dbw/main.htm
Gemini v3.20:
* Busybox 1.2.1
* Tuxtxt V1.99
Attention!
yellow button
* smbmount
(>=7000 )
more
./calendar.conf)
BMP, GIF or PNG)
(>=7000)
* cifs-1.42b
switchable.
NEW:
Fix + Update:
* attend CVS
* cifs-1.44
* Busybox 1.2.1
Interfaces WebIF:
number of cam)
number of cam)
