The Gemini Project 2.90 DM7000
Gemini v2.90:
* Enigma of: 03.05.2006
* GCC 3.4.4 Original CVS
* Web Interface: 5.9.2-Expert
* Busybox 1.01
* Tuxtxt V1.98
* 2x RED - EPG style menu
* GREEN - subservices
* Downloading and installation of additional features via Internet from Gemini server
* System Info: Many extra box infos (for example harddisk-temperature or all Enigma-settings)
* Download of Gemini news in background
* Support for OGG/Vorbis
* smbmount
* Support for CDROM/DVD, no matter if IDE or USB port ( >=7000 )
* Record CIFS/NFS: Record to a CIFS or NFS mounted harddisk (only working if there is no harddisk inside,
mountpoint set to "/mnt/usb" and at least 3GB disk space)
* Extra Menu: Settings for many extras like Inadyn, HTTPD, EPG-Cache, swap-out of "/var" and many more
* Backup function
* Backround pictures for Radio, MP3 and SCAN can be choosen via Blue Panel
* Calender including reminder (can be changed via .../gemini_cal.conf)
* New font and libfribidi for arabian
* EPG for Dishnetwork
* 2 new root entries for music and pictures can be created for the filemenu (BP->Extras/Settings->Root-Entry)
* Dreambox can be used as printserver(BP->Extras/Settings->Printer (LPD), FAQ can be found in the database
* Alarm clock with volume offset adjustable playing your own WAV-files.
* Display of current channel stream rates ( >=7000 )
* Dreamnetcast based on the new xml
* cifs-1.42b
Fix:
* Attend CVS
Interfaces WebIF:
http://127.0.0.1/cgi-bin/StopCam?ZAHL (ZAHL = Nummer des Cams)
http://127.0.0.1/cgi-bin/StartCam?ZAHL (ZAHL = Nummer des Cams)
We'd like to thank everybody who paricipated in the "Gemini suggestion" thread.
Unfortunatly many things can not be realized from our side.
and won't be supported!
Recommendation:
If you don't install the Image in flash memory, the flash image shouldn't be of a old version.
A swap file/partition (>= 16MB) should be present if several processes running in backround.
