Taas uusi PP
Jälleen uusi Peter Pan image.
Ei kummosia muutoksia:
- Based on Enigma of .0508
- Kernel 2.6.5 #36
- Module 1.08
- Auto Subtitle with Bullz Text 0.19
- Recording with subtitles
- Timeshifting
- Autorestore on Flasherase
- Built in language pack (nor, swe, dk)
- Web Interface: 1.4.0
- Emus
- NewCamd + Cardserver 5.11
- Scam 26.07
- Dreamcrypt 1.4
Known issues:
*) If you your dream crashes try to enable 32mb swapfile on USB/HDD that should do the trick.
When using pictureview your do need 100% the swap file
* When move var to HDD or USB picture can glitch at this end USB was better than HDD but on flash
it was 100% ok.
*) When using dreamflash -
language selection og channel may not stick, also some configuration may not be saved
CAUTION :
Do not use this as BASE image with DreamFlash 1.4
Solution :
Leave dreamflash out, the image are good enough Wink
- Kernel 2.6.5 #36
- Module 1.08
- Timeshifting
- Emus
- Scam 26.07
- Dreamcrypt 1.4
Known issues:
it was 100% ok.
CAUTION :
Solution :
