Pp 108_14072004
Pp 108_14072004
HI folks!!! :)
________________________________
- Based on Enigma of 02.07.2004
- Kernel 2.6.5 #36 (1.08)
- Bullz Text 0.15
- NewCamd + Cardserver 5.10
- Better orginal EPG than earlier firmware
- Internal cardreader working
- Auto Subtitle
- Recording with subtitles
- Timeshifting
- Autorestore on Flasherase
- Built in language pack (nor, swe, dk)
- Web Interface: 1.3.4
- Support for DreamFlash 1.4
- Plugins
- MultiView 2.1
- Sysinfo 0.4
- TuxCommander 1.3
- Aviable by PP Extra menu (Hack - SF team extra menu ) (blue button)
- Change subtitle to nor, swe, den, fin, eng (default nor) (blue button)
- Change subtitle background
- Change subtitle font (bold, medium or light)
- Mount / UMount CD-Rom
- NEW Backup and Restore - incl. old restore for compatible
- Tiny HDD Service menu
- Create HDD or USB Swapfile
- Create Corefile
- Move Addon to USB or HDD
- Keyupdate
- LAN Network configured trough DHCP
Known BUGS:
When changing bullz_text configuration the number of times doing that need to
be divied by two.
Solution :
Go back and select you language one more time.
ex:
When changing background to OFF you need lame out and select the language
one more time. If not you are only able to watch the channel you where currently on.
When using dreamflash language selection og channel wont stick, also some configuration will not be saved
Solution :
Leave dreamflash out, the image are good enough ;)
File Size: 5.72 MB
http://www.digsat.net/dload.php?action=category&cat_id=12
ramstad
