Octagon SF 918HD
Viesker
Kokkola
Vu+ Duo 4K
Vu+ Duo2
Octagon SF 918HD
Oiskohan tästä johonkin.
An elegant HDTV digital satellite receiver
- With LG tuner 32-bit 1000 MHz processor and 400 MB of memory provides OCTAGON the HD SF 918 for a strong and first-class reception.
- Enjoy the HD quality with less than 1 sec switching time of the programmes.
- With the Ethernet LAN connectivity, USB, eSATA and HDMI, they have the choice of agony
- Over the remote controlled tuner gain (AGC value) also enables the weak channels without interference to receive this receiver was unique.
- Individual color settings (brightness, contrast, color saturation) to its Sendungsart (film, news, sports, users) allows you the best image quality.
- Linux based
* 1000 MHz - 32-bit processor
* 400 MB RAM
* 10 000 memory places (TV & Radio)
* Ethernet LAN - 10/100 Mbps
* E-SATA port
* USB 2.0
* HDMI connector
* VFD display (Dot Matrix Vacuum Fluorescent Display)
* 2 x CI slots for modules
* Universal CONAX Smart Card reader
- An elegant HDTV digital satellite receiver
- Linux based
Only Arte features:
* 400 MB RAM
* E-SATA port
* USB 2.0
* HDMI connector
* Digital Satellite Receivers MPEG 4/H.264 & DVB-S2 (DVB) compatible
* Format Resolution: 576p/720p/1080i
* 3D user-friendly OSD Menu
* Clear and simple OSD surface
* Color Adjustment: color, brightness, contrast
* EPG (electronic program guide) for the display of program information and program preview
* 254 satellite programmable
* Level control DiSEqC 1.0, 1.1, 1.2 and 1.3 (USALS)
* LNB voltage 13/18V & 14/19V adjustable in long lines
* Video format in 4:3, 16:9 and letterbox
* Zoom & pause function
* Recall function: storing the last 20 selected stations
* Find function: stations can be found alphabetically
* Program timer function
* Sleep timer function
* 8 favourite lists for the organization of radio stations (film, news, sports, music, children, drama, family, Misc.)
* Parental Controls for menu and programs
* Several clear channel sorting functions such as delete, rename, move and block
* Backup & restore the setting (Backup / Restore)
* 8 buttons on the front panel
* Front buttons on / off switch
* Support for Teletext and subtitle
* Software - Updates on USB/RS-232 (PC-STB / STB STB)
* Data transfer: receiver to receiver
* Menu in 24 languages
* Games menu: Sokoban, Snake, Tetris, Mines, Slot Machine, Othello
* Calendar and calculator function
* Automatic NTSC / PAL detection
* Very fast channel search
* Multi-Search: several satellites can be marked and searched
* Manual input PID (audio, video and PCR)
* Volume difference for each channel individually adjustable
* Main background and radio background image ver ä nderbar
* Boat image on / off
* Selectable menu animations: Stripe, spray, Slide, Fade
* Power switch on / off
* HF Modualtor
* Dolby Digital 5.1 SPDIF output (optical)
* 2 x Scart (TV / CVR)
* 2 x RCA audio output (R / L)
* 1 x RCA video output
* Component component (YUV - YPbPr)
* Dimensions: 340 x 60 x 268 mm
* Weight: about 2.8 kg
dt125
Keski-Suomi
    53.3 KB · Lukukerrat: 448
    14.7 KB · Lukukerrat: 441
Lumikki
Länsi Kanta-Häme
19E,26E,28E 121cm
Vu+ Solo2 (2xS2) OA 5.3
Vu+ SoloSE (2xT2) OA 5.1
NUC5+ Kodi (18.8) Libre
RPi3B+ Kodi (17.6) Libre
LG C9 65" ja LCD 40"
AV Yamaha RX-V375
Proson 5.1
Lumikki
Länsi Kanta-Häme
19E,26E,28E 121cm
AV Yamaha RX-V375
Proson 5.1
Hexi
aov
