Newnigma2 v2.8.4: 800,8000,7025(+),500HD
Newnigma2 team proudly presents:
Newnigma2 v2.8.4
Basics:
* Enigma2 2.6: 19.02.2010
* Enigma2 Plugins 2.6: 19.02.2010
* Newnigma2 Plugins: 19.02.2010
DM 800 HD PVR
* driver: 17.01.2010
* secondstage: 75
DM 8000 HD PVR
* secondstage: 76
DM 7025+
* driver: 04.01.2010
* secondstage: 76
DM 500 HD
* driver: 27.01.2010
* secondstage: 77
Changelog:
* new plugin
Blue Button -> Newnigma2 Services -> System Tools -> Expert Menu
Here you can allow to install Picons into the flash, or you can activate the picondebug (missing picons will be added to "the
missing-skin-hd-picons.txt" file).
* new option:
Menu Button - Settings -> System -> Harddisk -> Harddisk Settings
Here can set the USB harddisk in the standby modus. standby settings are from 10 seconds to 4 hours valid.
* keymap: neutrino and neutrino_half:
shift + 1 = power on from standby.
* config-saver:
crashes with the SD-Skins are fixed.
* nfs-server:
NFSD-modul will be now loaded at startup, this fixes errors in 2.8.3.
* opkg:
installation and unintall of plugins now works properly. There were some problems with 2.8.3.
* picon-hd-skin: fixes
SKY Bundesliga Picons are now shown on all feeds. Some picons are completely rebuilded. The 3D picons are completly new.
* new skins:
only support for skins, that are on the feed.
IMPORTANT
It is possible to update from 2.8.3 to 2.8.4 via Softwareupdate or console.
With the release of our 2.8.3 image there have been introduced some quite generic changes, for example: it was not possible to install picons to flash, or the linking of USB-Memory-Sticks was removed. With the current 2.8.4 image these kind of changes were further extended.
DM800 users can now install the picons in the flash again. But be carefully there is limited space avaible. DM8000 can install the picons to the flash too, there will be a Picon folder in the root of the image, DM8000 has enough space to store picons in flash.
The linking of of devices like an usb stick in the devicemanager is gone. There were too much problems with linking devices. Some little plugins are not work anymore, but its known. You can change the record path in the menu: settings -> system - record path, here you can change all you need.
800: http://www.newnigma2.to/wbb2/jgs_db.php?action=download&download_id=82&sid=
8000: http://www.newnigma2.to/wbb2/jgs_db.php?action=download&download_id=83&sid=
7025(+): http://www.newnigma2.to/wbb2/jgs_db.php?action=download&download_id=84&sid=
500HD: http://www.newnigma2.to/wbb2/jgs_db.php?action=download&download_id=81&sid=
Newnigma2 v2.8.4
Basics:
DM 800 HD PVR
* secondstage: 75
DM 8000 HD PVR
* secondstage: 76
DM 7025+
* secondstage: 76
DM 500 HD
* secondstage: 77
Changelog:
* new plugin
* new option:
* config-saver:
* nfs-server:
* opkg:
* new skins:
IMPORTANT
