Neutrino.DREAM Plus 1003Z DM-7000
Welcome on Neutrino.DREAM Plus!
THERE IS NO ANY EMU INSIDE!
file: dm7000_nplus_1003Z.img
md5sum: E486F649F7E5B926AFFD9FCD9563B600
version=2109200510032323
comment=ruDbox dream image
creator=ruDbox
credits=dbox2world team, rudream
2005 10 06
public
2005 10 03
added new kernel: 2.6.9 w/squashfs 2.2-r2 lzma patch support
added head.ko beta109_1-20050918-usbtest
added fixs nhttpd and sectionsd
added yWeb Version 1.3.4/tuxbox cvs
added new option for recording - sub-directory w/channel name /tuxbox cvs
adeed all locales inside
added polsat_epg.ttf
adeed little more games and plugins
added all samba modules, but neutrino hasn't gui for it
added pre-install fwpro v.7020 b3
added tools for pack and unpack images w/squashfs 2.2-r2 lzma patch
How to unpack images w/squashfs 2.2-r2 lzma?
see log for example:
<start--
welcome on your dreambox! - Kernel 2.6.9 (09:34:43).
dreambox login: root
Password:
BusyBox v1.00 (2005.09.06-17:18+0000) Built-in shell (ash)
Enter 'help' for a list of built-in commands.
dreambox ~ > cd /var/mnt/usb/rudbox/
dreambox /var/mnt/usb/rudbox > undreamboxfs NBC_CVSplus_02.10.2005.DM7000.img NBC_CVSplus
Need the uncramfs tool in local dir
See original package
dreambox /var/mnt/usb/rudbox > cp -a /bin/uncramfs /var/mnt/usb/rudbox
9304+0 records in
9304+0 records out
Done!
--end>
How to pack images w/squashfs 2.2-r2 lzma?
For packing new images You nee more memory and more time for it.
Example: create swap_file
dd if=/dev/zero of=/hdd/swap_file bs=1024 count=262144
mkswap /hdd/swap_file
swapon /hdd/swap_file
Now You start to build pack new image w/squashfs 2.2-r2 lzma.
Use telnet, set to working directory.
Example.
<start--
dreambox /var/mnt/usb/2005/rudbox > mkdreamboxfs dm7000_nplus_1003Z dm7000_nplus_1003ZZ.img
Directory data: 164 bytes
Everything: 1116 kilobytes
Super block: 76 bytes
CRC: ca1a5f69
36864+0 records in
36864+0 records out
Ready to make the squashFS part! This can take 1 or 2 minutes!
Creating big endian 2.1 filesystem on tmp_mkdreambox_3, block size 65536.
Big endian filesystem, data block size 65536, compressed data, compressed metadata, compressed fragments
Filesystem size 4960.65 Kbytes (4.84 Mbytes)
38.14% of uncompressed filesystem size (13006.55 Kbytes)
Inode table size 4539 bytes (4.43 Kbytes)
30.45% of uncompressed inode table size (14906 bytes)
Directory table size 4621 bytes (4.51 Kbytes)
54.33% of uncompressed directory table size (8506 bytes)
Number of duplicate files found 10
Number of inodes 654
Number of files 468
Number of fragments 45
Number of symbolic links 124
Number of device nodes 0
Number of fifo nodes 0
Number of socket nodes 0
Number of directories 62
Number of uids 1
root (0)
Number of gids 0
Done!
<end--
That's all
*********DONT ASK US ABOUT NEUTRINO.DREAM AND CAMD3 WORKING! ASKiNG AUTHOR OF CAMD3 DIRECT!*********
NOW BEFORE YOU START TO CLEAR INSTALLATION Neutrino.DREAM EVERYTIME,
YOU CAN STORE ALL YOUR SETTINGS BY NEW SCRIPT-BACKUP!
INSTALL addon_backup.bin TO YOUR Neutrino.DREAM AT FIRST TO SAVE SETTINGS.
WE'RE USING Neutrino.DREAM AS BASE IMAGE ON DREAMBOX!
FLASHING IS SAME AS DMM-IMAGE. NEUTRINO GUI DOES NOT SUPPORT CI-CAM.
THERE IS WE HAVE PRE-INSTALL FLASHWIZARD BOOT AND DREAMSET EDITOR PLUGIN INSIDE OUR IMAGES.
FULL VERSIONS OF FLASHWIZARD AND DREAMSET EDITOR YOU'LL CAN FIND AT:
FlashWizard PRO by MusicBob - _http://satnews.it,
DreamSet by John Vossos, Athens, Greece - _http://mmedit9800.tripod.com.
SOME INFORMATION ABOUT Neutrino.DREAM WILL BE USEFULL FROM NEXT FORUMS:
_http://www.info-sat.org,_http://www.satnews.it, _http://sat-industry.net,
_http://www.allrussian.info,
_http://rudbox.da.ru.
ruDbox Team
#dbox2 /Dalnet
http://www.dreamsite.dvb-z.net/image/7000/dm7000_nplus_1003Z.zip
creator=ruDbox
2005 10 06
public
2005 10 03
<start--
Password:
9304+0 records in
9304+0 records out
Done!
--end>
Example.
<start--
CRC: ca1a5f69
36864+0 records in
36864+0 records out
Number of files 468
Number of uids 1
root (0)
Number of gids 0
Done!
<end--
That's all
ruDbox Team
#dbox2 /Dalnet
