Nabilosat Enigma2 Black Hole - DM800 v0.8 AG
predators
Advanced Graphics
What is new in this version 0.8AG ?
Nabilosat v 0.8AG is the first image introducing advanced graphic engine with effects and animations.
The graphic engine is highly optimized to have the best and faster E2 image in HD resolution 1280x720.
New: HD skin Black Shadow By Matrix
New: Bootlogos by Maximo II
New: Enigma graphic enigne startup directly in HD
New: Animations in Cam starting
New: Animations in Addons Server connections
New: New and Revolutionary Graphic System Monitor Panel (1x Blue + 1x Yellow)
New: Monitor popup animation in System Monitor Panel
Enigma2 CVS date 15/02/2009 experimental 2.6
Drivers date 07/02/2009
Second Stage #70-pr1
NOTE
Plugins are available for download from the Nabilosat Addons Panel. Press the Green button and then the Yellow button to launch the Addons Panel.
Main Function Keys
Button 1xOK = Light Info Skin
Button 2xOK = Extra Info Skin
Button 1x Blue + 1x Yellow = New System Monitor Panel
Button Red = Start Record
Button Yellow = Time Shift
Addons
Dedicated Addons Server
Download and install additional packages from Nabilosat server
Infobar/OSD
Enigma2 Analogic Clock
Channel Orbital Position
Signal SNR, BER
Infobar Picons
LCD/OLED Picons
Advanced EMU information
Nabilo Panels features
1) Blue Panel
Setup
OSD Settings
Nabilosat E2 EPG Settings
NEW LCD Settings
Fast Plugin Settings
Inadyn Settings
Swap File Settings
Hard Disk Setup
Nabilo Mount Wizard
OpenVPN Panel
Samba/Cifs Panel
NFS Server Panel
Telnet Panel
FTP Panel
CCcam Info
Service Info
Enigma2 Settings
About
Memory Info
Space
CPU
Process
Save
Select/Start/Restart EMU
2) Green Panel
Shoutbox
Fast Plugin
Addons
Addons Download Manager
Manual Install Nab packages
Manual Install IPK packages
Addons Uninstall Panel
Nabilosat Statistics
Scripts
^^Corrado^^, Neri73, ferbius, robyhummy, nixus, greg, lorenzo64, matrix10
Credits
Matrix10 for the new Black Shadow skin.
^^MaXiMo^^ for bootlogos.
Army for the new System Monitor Panel
Backups or other modified Images are not supported.
WARNING. If you install this image to multiboot, you must install Nabilosat Pure Flash 18FEB2009 to flash..
Latauslinkki: http://www.mediafire.com/?ltt2g2wh2vz
Palautteen ja pikaisen testauksen jälkeen ehkä nopein/paras image/skini DM800 mitä on tähän mennessä tullut. Jokainen testatkoot ja kertokoot tulokset.
