Nabilosat DM7020-0.6 PLUS NFI
Firmware for DM7020 Flash and Multiboot USB/HDD/CF
This is a Nabilosat Image with important additions.
This Nabilosat image include Tun/Tap kernel module and Openvpn fully version and plugin.
This Nabilosat image include a Picons package too (you have only to enable picons in Nabilosat ODS Preferences).
Warning: Openvpn is fully included in this version. Don't install Openvpn plugin in this image.
What's new:
* - New Default Skin Army Wire with double style Menu and OSD lite (Warning old skins are not compatible with Nabilosat 0.6 image).
* - New Webif personalized by Army for Nabilosat
* - Added Webif Nabilosat Emu manager (Start/Change/Manage Emus by Webif).
* - Added Double style menu configuration (dreambox default and Nabilosat style)
* - Added Lite OSD skin when zapping option.
* - Added Infobar OSD position configurable (x and y offset).
* - Added internal System picons (Nabilosat 0.6 doesn't need picon plugin. Picons are image internal and doesn't not effect the zap perfomance and speed. Some picons (Rai and Multivision are included in image. You have only to enable option in Nabilo OSD preferences).
* - Added picons location settings.
* - Added Skin preview in Skin Selector manager
* - Added NABILOSAT INTERNAL CRON
* ---- Epg Refresh Scheduler
* ---- Cam Restart Scheduler
* ---- Commands or scripts execution scheduler
* - Changed Inadyn script: Inadyn log now enabled.
* - Added a graphical interface to show the Inadyn log. (Warning don't use old inadyn_script.sh. New inadyn script is not compatible with previous versions).
* - Added User Script Manager, (put your script in dir /var/scripts/xxx_userscript.sh)
* - Added date (short format) to OSD info
* - Added videoformat to OSD info
Here is New Skin:
http://www.nabilosat.info/images/shots/W1.jpg
Here is ODS Lite Infobar when option for lite skin zapping is enabled:
http://www.nabilosat.info/images/shots/W2.jpg
Here is New Skin in compact version:
http://www.nabilosat.info/images/shots/W3.jpg
Here is Double Menu Configuration:
http://www.nabilosat.info/images/shots/W6.jpg
Here is Dreambox default style menu:
http://www.nabilosat.info/images/shots/W4.jpg
Here is Nabilosat style menu:
http://www.nabilosat.info/images/shots/W5.jpg
Here is Nabilosat Personalized Webif:
http://www.nabilosat.info/images/shots/W7.jpg
Webif Control Panel:
http://www.nabilosat.info/images/shots/W8.jpg
Webif Emu Panel:
http://www.nabilosat.info/images/shots/W9.jpg
Nabilosat OSD preferences (not you can set the Osd position, Enable Lite Skin when zapping and enable internal picons:
http://www.nabilosat.info/images/shots/W10.jpg
Nabilosat skin selctor (note the skin preview):
http://www.nabilosat.info/images/shots/W11.jpg
Nabilosat userscript (you can add your scripts to image):
http://www.nabilosat.info/images/shots/W12.jpg
Nabilosat Cron (note you can plannig emu restart - epg refresh - scripts - or system commands execution):
http://www.nabilosat.info/images/shots/W13.jpg
Nabilosat Inadyn Log:
http://www.nabilosat.info/images/shots/W14.png
Openvpn Plugin:
http://www.nabilosat.info/images/shots/W15.png
http://www.nabilosat.info/images/shots/W16.png
* BLUE NabiloCam Blue Panel
* YELLOW NabiloCp Yellow Panel
* 2x RED - EPG style menu
* GREEN - subservices
--- NabiloCam Blue Panel (BLUE BUTTON)
* BLUE - Cam Manager (Start - Restart - Change - Auto Provider - Auto Channel ECM INFO IN PANEL)
* BLUE -> RED Fast Key donwload and Update
* BLUE -> GREEN Save default cam and Provider and Channel Autocam
* BLUE -> BLUE Extra Settings
* BLUE -> YELLOW System Info
--- Extra Settings (BLUE -> BLUE BUTTON)
* SWAP FILE config
* INADYN config
* HARD DISK settings
* EPG settings
* OSD preferences
--- System Info (BLUE -> YELLOW BUTTON)
* DB Info
* Mount Points
* Process Info
* Memory Info
* Enigma Setup
* Bitstream
--- NabiloCp Yellow Panel (YELLOW BUTTON)
* YELLOW -> YELLOW Plugins
* YELLOW -> BLUE User Scripts (put your script in /usr/script/xxxx_userscript.sh)
* ADDONS DOWNLOAD MANAGER (Download and auto-install addons and OTHER DREAMBOX IMAGES)
* ADDONS MANUAL INSTALL PANEL (Put packages in /temp and install via manual panel)
* ADDONS UNINSTALL PANEL
* IMAGES UNINSTALL PANEL (Uninstall images you have in your Hdd/Usb/Cf)
* NABILOSAT FORUM (Read main Nabilosat Forums in your Dreambox)
* NABILOSAT SHOUTBOX (Chat with other Dreambox Users)
* SHOUTBOX NICK CONFIG (Set you nick for Nabilosat SHoutbox)
* Nabilosat addon server via internet.
* Shoutbox server via internet.
* MOST POPULAR DREAMBOX IMAGES CAN BE DOWNLOADED INSTALLED AND REMOVED FROM NABILOSAT IMAGE ADDON PANEL
* Fast K update directly from Blue Panel
* ECM INFO AVAILABLE DIRECTLY IN BLUE PANEL
* OSD: Extra Info switchable
* OSD ADDED INFO:
*** netcard_info
*** ecm_info
*** pro_name
*** feq
*** pol
*** sr_snr
*** fc_fec
*** cam_info
*** crypto_info irdeto_ecm seca_ecm via_ecm nagra_ecm cw_ecm nds_ecm conax_ecm beta_ecm
*** icon smartcard
*** icon emu
*** icon network
* System Info: Many extra box infos
* Nabilosat Forum browsing
* Extra menu: Settings for many features like Inadyn, Swap, EPG-Cache and many more
* Own scripts can be started via Yellow Panel
* Epg Cache Advanced:
*** Popop Notice When EPG stream channel found
*** Popup Notice Epg downloading in progress
*** Popup Notice To not change channel until download completed
*** Popup Notice When Epg Download is completed and saved
* SKIN PREVIEW IN SKIN SELECTOR
No Keys, No Emu Inside.
Original epg_cache code is by aalex77.
Special Thanks to aalex77 and Juliet team to help to improve Epg in Nabilosat Image.
Thanks to all the PPL that contributhed to this version:
Nabilo - Franjuve and all the beta tester
Many Thanks to Army for Nabilosat skin and Webif personalization
Many Thanks to Matrix10 for Wonderful Skins and the testing and inspirations of major additions
Special thanks to greg, the best Beta Tester in the world :)
Many Thanks to all beta testers.
Special Thanks to Fbrassin for is great work to provide to Nabilosat ppl packages.
Special Thanks to Piefav genge and Sif team for openvpn study and testing.
Enjoy Nabilosat ..
