Nabilosat DM500 v. 0.6.1 Plus
Nabilosat DM500 v. 0.6.1 Plus & MaxVar
Firmware for Dreambox DM500
Hi Nabilo Ppl.
Here are two versions of Nablosat Image DM500 available
1. Nabilosat DM500 v. 0.6.1 Plus
2. Nabilosat DM500 v. 0.6.1 MaxVar
What is the difference between these two images?
1) Nabilosat DM500 Plus: is the most advanced Nabilosat Image. This version include Openvpn fully integrated in Enigma. If you use this image you don't need to intall openvpn plugin because Opevpn is fully included in this image.
2) Nabilosat DM 500 MaxVar: this version is compiled and optimized to have the maximum extra space in /var directory. This version doesn't include Openvpn. So if you don't want to use Openvpn this is your image. With this MaxVar version you have about of total 2.8 M space available on /var.
These are the only differences between these two versions all the rest is the same.
Warning: to install this image in flash Use ONLY DreamUP + serial cable and a complete flash erase.
Don't install this image in flash with flashwizard.
* Enigma of: 28.3.2007
* GCC Original CVS
* Web Interface: Nabilosat Personalized by Army
* Busybox 1.2.2
What'new in Nabilosat Images 0.6.1 ?
Included G*** Center
Included Nabilosat CCcam Info Center
Added Option to Use 7000 - 7020 Remote control instead of 500 Remote Control
Added in OSD CCcam Network Info:
* Network address
* hops
* ecm time
Here is ODS Net info added for CCcam:
http://www.nabilosat.info/images/shots/W18.png
* GCC Original CVS
* Busybox 1.2.2
Major Features
* - Default Skin Army Wire with double style Menu .
* - New Webif personalized by Army for Nabilosat
* - Webif Nabilosat Emu manager (Start/Change/Manage Emus by Webif).
* - Double style menu configuration (dreambox default and Nabilosat style)
* - Infobar OSD position configurable (x and y offset).
* - internal System picons[/color] (Nabilosat 0.6 doesn't need picon plugin. Picons are image internal and doesn't not effect the zap perfomance and speed.
* - picons location settings.
* - NABILOSAT INTERNAL CRON
* ---- Epg Refresh Scheduler
* ---- Cam Restart Scheduler
* ---- Commands or scripts execution scheduler
* - Inadyn script: Inadyn log now enabled.
* - graphical interface to show the Inadyn log. (Warning don't use old inadyn_script.sh. New inadyn script is not compatible with previous versions).
* - User Script Manager, (put your script in dir /var/scripts/xxx_userscript.sh)
Here are some shoots Skin:
http://www.nabilosat.info/images/shots/W1.jpg
Here is New Skin in compact version:
http://www.nabilosat.info/images/shots/W3.jpg
Here is Double Menu Configuration:
http://www.nabilosat.info/images/shots/W6.jpg
Here is Dreambox default style menu:
http://www.nabilosat.info/images/shots/W4.jpg
Here is Nabilosat style menu:
http://www.nabilosat.info/images/shots/W5.jpg
Here is Nabilosat Personalized Webif:
http://www.nabilosat.info/images/shots/W7.jpg
Webif Control Panel:
http://www.nabilosat.info/images/shots/W8.jpg
Webif Emu Panel:
http://www.nabilosat.info/images/shots/W9.jpg
Nabilosat userscript (you can add your scripts to image):
http://www.nabilosat.info/images/shots/W12.jpg
Nabilosat Cron (note you can plannig emu restart - epg refresh - scripts - or system commands execution):
http://www.nabilosat.info/images/shots/W13.jpg
Nabilosat Inadyn Log:
http://www.nabilosat.info/images/shots/W14.png
Openvpn Plugin:
http://www.nabilosat.info/images/shots/W15.png
http://www.nabilosat.info/images/shots/W16.png
* BLUE NabiloCam Blue Panel
* YELLOW NabiloCp Yellow Panel
* 2x RED - EPG style menu
* GREEN - subservices
--- NabiloCam Blue Panel (BLUE BUTTON)
* BLUE - Cam Manager (Start - Restart - Change - Auto Provider - Auto Channel ECM INFO IN PANEL)
* BLUE -> RED Fast Key donwload and Update
* BLUE -> GREEN Save default cam and Provider and Channel Autocam
* BLUE -> BLUE Extra Settings
* BLUE -> YELLOW System Info
--- Extra Settings (BLUE -> BLUE BUTTON)
* Openvpn Manager (Plus version Only)
* INADYN config
* OSD preferences
--- System Info (BLUE -> YELLOW BUTTON)
* DB Info
* Mount Points
* Process Info
* Memory Info
* Enigma Setup
* Bitstream
--- NabiloCp Yellow Panel (YELLOW BUTTON)
* YELLOW -> YELLOW Plugins
* YELLOW -> BLUE User Scripts (put your script in /usr/script/xxxx_userscript.sh)
* ADDONS DOWNLOAD MANAGER (Download and auto-install addons and OTHER DREAMBOX IMAGES)
* ADDONS MANUAL INSTALL PANEL (Put packages in /temp and install via manual panel)
* ADDONS UNINSTALL PANEL
* NABILOSAT FORUM (Read main Nabilosat Forums in your Dreambox)
* NABILOSAT SHOUTBOX (Chat with other Dreambox Users)
* SHOUTBOX NICK CONFIG (Set you nick for Nabilosat SHoutbox)
* Nabilosat addon server via internet.
* Shoutbox server via internet.
* Fast K update directly from Blue Panel
* ECM INFO AVAILABLE DIRECTLY IN BLUE PANEL
* OSD: Extra Info switchable
* OSD ADDED INFO:
*** netcard_info
*** ecm_info
*** pro_name
*** feq
*** pol
*** sr_snr
*** fc_fec
*** cam_info
*** crypto_info irdeto_ecm seca_ecm via_ecm nagra_ecm cw_ecm nds_ecm conax_ecm beta_ecm
*** icon smartcard
*** icon emu
*** icon network
* System Info: Many extra box infos
* Nabilosat Forum browsing
* Extra menu: Settings for many features
* Own scripts can be started via Yellow Panel
www.hitechplace.com/nabilo
No Keys, No Emu Inside.
Thanks to all the PPL that contributhed to this version:
Nabilo - Franjuve and all the beta tester
Many Thanks to Army for Nabilosat skin and Webif personalization
Many Thanks to Matrix10 for Wonderful Skins and the testing and inspirations of major additions
Special thanks to greg, the best Beta Tester in the world :)
Many Thanks to all beta testers.
Special Thanks to Fbrassin for is great work to provide to Nabilosat ppl packages.
Special Thanks to Piefav for openvpn study and testing.
Special Thanks to Bacicciosat our best image coder
Enjoy Nabilosat !!
