Nabilosat Black Hole DM800v0.5F2 12.12.2008
Nabilosat Enigma2 Black Hole - DM7025 v0.5F2
What is new in this version 0.5F2 ?
Enigma2 Version 2.6 experimental
This version of Nabilosat Black Hole is using the experimental version 2.6 of Enigma2. The image is very fast, reliable. Zap speed is even better than ever​
NOTE
You can install this image to flash, without any further support.
You can install this image to multiboot. In this case, you must have an updated image installed to flash. Else, many new features will not work properly.
Nabilosat team reccomends the Nabilosat DM 7025 Pure Flash dated 12 December 2008, available here, or other images released from today onwards. The CVS of the image in flash must be after 10 December 2008.​
Enigma2 CVS date
10/12/2008​
Updated DVB Drivers
The DVB Drivers are now the latest available version, improving cardreader speed. Many thanks to Linsat Team for the report.​
New skin Black Cat by Army
Army released a brand new skin for this new version of Black Hole​
Enigma2 Integrated Sky IT EPG
Updated Sky EPG IT, including full titles for 8 days. By MaxZ4​
OSD with Channel Number
The OSD Info Bar will now display the channel list number.​
OSD with Orbital Position and Satellite Name
The OSD Extra Info Bar will now display the Satellite name and orbital position​
Drives and CVS
Updated to the lastest available version
Web Interface
Updated Nabilosat Web Interface.​
Web Interface
Button icons fixed. Now you know what to press on your remote control.​
NEW NEW NEW: Latest Plugins CVS 10 December 2008 directly tested and integrated in the image
configurationbackup
DVDplayer
DVDburn
mediascanner
webinterface
graphmultiepg
pictureplayer
mediaplayer
antiscrollbar
autotimer
emailclient
epgrefresh
fritzcall
googlemaps
httpproxy
imdb
lastfm
mosaic
ofdb
passwordchanger
permanentclock
rsdownloader
simplerss
startuptostandby
trafficinfo
unwetterinfo
vlcplayer
webcamviewer
werbezapper
zaphistorybrowser​
NOTE. Most plugins will be available in MENU>PLUGINS or Nabilo Green Panel. Other plugins will be available in the Extesions Menu ( long press blue button )
NOTE. Permanent Clock is disabled by default. To enable it, go to Green Panel > Permanent Clock.
Main Function Keys
Button 1xOK = Light Info Skin
Button 2xOK = Extra Info Skin
Button Red = Start Record
Button Yellow = Time Shift​
Addons
Dedicated Addons Server
Infobar/OSD
Enigma2 Analogic Clock
Channel Orbital Position
Signal SNR, BER
Infobar Picons
LCD/OLED Picons
Advanced EMU information​
Nabilo Panels features
1) Blue Panel
Setup
OSD Settings
Nabilosat E2 EPG Settings
LCD Settings
Fast Plugin Settings
Inadyn Settings
Swap File Settings
Hard Disk Setup
Nabilo Mount Wizard
OpenVPN Panel
Samba/Cifs Panel
NFS Server Panel
Telnet Panel
FTP Panel​
Info
CCcam Info
Memory Info
Available Space
Processes
Service Info
Enigma2 Settings
About​
Save
Select/Start/Restart EMU​
2) Green Panel
Shoutbox
Fast Plugin
Addons
Addons Download Manager
Manual Install Nab packages
Manual Install IPK packages
Addons Uninstall Panel
Nabilosat Statistics​
Scripts
Black33, ^^Corrado^^, Maximo II, greg, Matrix10, Porto, Nabilo, Army, Piefav, Franzjuve, Willow, fbrassin, Neri73, paribas, astemio, lorenzo64, frimmino, robyhummy, DeepDiver
Credits
Army for the new Black Cat skin.
Backups or other modified Images are not supported!
WARNING.
This image includes the latest available DVB drivers. Therefore, if you install it to multiboot, it will not work with any previous image in flash. If you install it to multiboot, you must install either the Nabilosat Pure Flash DM 7025 dated 12 December 2008, or any other image release from today onwards.
