Nabilo BlackHole v02b (800)
crashi
What is new in this version 0.2bNew Video Drivers.
New OE entirely rebuild
New Enigma 2.5 experimental CVS of 11.6.2008New bootlogos
Now working FFWD up to 128x
New *** starting inside Enigma2
Added Nfs Server panel
Automatic Enigma2 restart for Nabilo Server addons
Enigma2 version date: 11 June 2008
Openvpn Kernel module support included. Openvpn fully embedded in graphic interface.
Default Skin : Army Niro
Alternative Skin : Porto Invader
Main Function ***s
Button 1xOK = Light Info Skin
Button 2xOK = Extra Info Skin
Button Red = Start Record
Button Yellow = Time Shift
Addons
Dedicated Addons Server
Download and install additional packages from Nabilosat server
Infobar/OSD
NEW Introducing Analogic Clock to Enigma2
Channel Orbital Position
Signal SNR, AGC, BER
Infobar Picons
LCD/OLED Picons
Advanced *** information
Nabilo Panels features
1) Blue Panel
Setup
OSD Settings
Fast Plugin Settings
Inadyn Settings
Swap File Settings
Hard Disk Setup
OpenVPN Panel
Samba/Cifs Panel
NFS Server Panel
Telnet Panel
FTP Panel
Info
C**** Info
Memory Info
Available Space
Processes
Service Info
Enigma2 Settings
About
Save
Select/Start/Restart ***
2) Green Panel
Shoutbox
Fast Plugin
Addons
Addons Download Manager
Manual Install Nab packages
Manual Install IPK packages
Addons Uninstall Panel
Nabilosat Statistics
Scripts
Black33, ^^Corrado^^, Maximo II, greg, Matrix10, Porto, Nabilo, Army, Piefav, Franzjuve, Willow, MaxZ4, fbrassin, Neri73, DeepDiver
Nabilosat Team highly recomme*** you to upgrade your Black Hole image to version 0.2b
For multiboot use, Oozoon images are recommended as your choiche for flash image.
This image does not contain any ***s or softcams inside.
HOW TO SETUP NFS SERVER
Test Nfs server is easy if you have more than one dreambox in your home.
As for example:
if you have another dream in your home with nfs you can easly use as a client to connect to your 800 and mount its hd.
You can follow this procedure. We wil suppose that you have this configuration in your net:
First dreambox: DM 800 with Black Hole RC10 ip: 192.168.0.7
Second dremabox: ip: 192.168.0.8.
1) Go to the Black Hole bluepanel->Settings->Nfs Panel
2) Change the ip of the client to 192.168.0.8
3) Enable Nfs server
4) Start Nfs Server from panel
5) From your Pc telnet to your second dremabox (your client) and type this command: mount 192.168.0.7:/media/hdd /media/net
Now you will have the 800 hdd mount on the /media/net dir of your client.
(P.s. If your dreambox client is an Enigma1 dream and it does not have the nfs server included, install Nabilosat DarkStar image).
The following are screenshots are taken from the default Army Niro Skin
We will all fall deep inside the Black Hole...there is no way out
http://www.dreamboxworld.org/dbw/dm800/nabilo/NabiloBlackHole_DM800_02b.zip
