MeoBoot
MeoBoot
MeoBoot is a new, very light, not invasive, Multiboot tool for Enigma 2 images.
MeoBoot is the answer to those who wish to have an alternative to the existing multiboot tools, which have now become a kind of image in the image, controlling your DM, doing tasks that go beyond their purposes, reaching large file sizes.
System requirements:
MeoBoot is currently designed to work only with Enigma 2 images for Drembox series DM8xx, namely for dm800 and DM8000.
MeoBoot can be installed on a standard CF (Compact Flash), an SD card, or a normal USB key.
MeoBoot only accepts devices formatted in Linux (part1) and this to ensure the best performance in dreambox native environment.
The HDD install option is not available. The HDD standby feature makes the HDD install a bad solution, and therefore the USB, CF and SD are preferred instead.
Operation:
MeoBoot is very simple and intuitive. The plugin includes an Help button, explaining where to upload images before install and how to remove it. It also includes a feature to format the device where the MultiBoot will be used.
About multiboot tools, and suggestions on how to keep the image always updated.
An insight of all multiboot tools would require understanding that DMM second stage are not possible to modify.
This means that the current multiboot tools may intervene in the process of starting the Dreambox only after the kernel and Secondstage have been loaded.
It is therefore importanto to understand that when using a multi-boot tool, the drivers, secondstage and kernel will be loaded by the flash image.
This procedure requires some precautions:
1) It is a good idea to always update the flash image, to make sure it includes the latest drivers and secondstage. Drivers and Secondstage can be easily updated via the Software Manager, available in the flash image. If the drivers and secondstage of your flash image are old, they will also be used for the new images you will install to multiboot.
2) Do not install to multiboot images too old, compared to the flash image. They may not work properly when the drivers are very recent, and the CVS is very old.
3) Do not use images in multiboot with different kernel versions. This may cause the malfunction of your whole dream.
For example, do not use the latest OzOon images with Nabilo, LS, Gimini or NewEnigma. Ozoon latest images include a different kernel and are incompatible.
To avoid trouble then before installing a new image, always check the image kernel version, and make sure it is the same as the flash image.
These are few and simple explanations that are relevant to all multi-boot tools and if you follow them, you will then make sure that your Dream always performs at itsbest, keeping it as much as possible efficient and updated.
MeoBoot was written precisely for this to be simple, transparent and lightweight.
It is very small compared to other MB and does not reach even a mega.
It only does its job, and does not invade your dream, do not check if it is a clone or not, check your network, it does nothing extra. Only does multiboot.
