- 3 * Nvidia Shield + Synology NAS DS218+ LG 77CX6LA + Genelec + RasPi/rAudio + Adam T5V + T7V + T10S - ArcoLinux
LT - The Fifth Campaign DM800 & 7025 SP3
Howdy all LT Users out there!
Here we have the first SP for newest LT image! We have worked hard and listened to many of your requests. Not all could make it in.but many have. Please see the detailed list for all changes.
Enigma2 CVS 20080905
Drivers dm800 20080821
Drivers dm7025 20080826
IMPORTANT! There has been a change to the EPG data file so you **MUST** remove old grabbed files **BEFORE** you install the new image.
I.e. remove this file: /media/usb/epg_external.dat (or if using CF /media/cf/epg_external.dat)
THIS IS VERY IMPORTANT!
Good luck and happy dreaming!
/LT-Team
-New configuration: Show sleep-timer in shutdown menu (yes/no)
-Added Quick-Button option to shift+color buttons. Have a look at the files /usr/LTMenu/*color*.txt
-Added lt.po, is.po and fr.po to the image, used the files from ltteam.org
-Syslogd config GUI and script for autostart
-Added possibility to switch with the blue button in LT EPG to the old Multi EPG
-Added support for help-texts in LT-Config-screen
-Since we have the autofs stuff in our image we can start automount on bootup looking for the file /etc/automount.conf
-Now you can show Now-Event and Next-Event in the Channel-Selection screen. Maybe nice thing for High-def-skins?!
-Now you can load kernel-modules on bootup. The config-screen for that can be found in Menu => LT Menu => Extras (Tools) => Kernel Modules
-Dutch translation. Thanx to BigM.
Changes:
-Don't crash if InfoPanel can't connect to newcs
-FIX: Crash using DVD-Player and Subservice-Quickzap
-Fix: Mount-Manager nfs-mounts didn't work
-Moved all skin-related stuff in an own menu
-Fix: Reported skin-issues (LT.GlassLine.II)
Changes MC:
-Better getFlv download links handling
-Show error-message if streamload is offline
-Fix crash using cover-art in screen-saver
-FIX crash reading image-size in picture-player
-New configuration for Stream-Player: Transcode mpg/mpeg (yes/no)
-New configuration for Stream-Player: Transcode vob (yes/no)
-Don't play the last file again and again and again and..
-Fix stopping music for some seconds in SHOUTcaster when adding a channel to the favourites
-Fix stopping music for some seconds when adding a music-title to the playlist
-Browser for CD/DVD
-Play Audio-CD (basic version. album/artist and title not shown atm)
Changes EPG-Grabber:
-EPG grabfile for Australian Optus c1 Satellite
-Place the box into standby after grabbing external EPG if restart is choosen
-Added protection for "faulty syntax" on RadioTimes grab. Will solve crashing because of "dead links" etc.
-Combination of nordic_swedb.xml and radiotimes.xml updated by shshadm at www.satlovers.se
-Moved the grabbers outside the "closed source file". This means that we want to include full source for all stuff in "EpgGrabbers". This way people can extend and create new grabbers for all types of data.nice!
-Added first version of native grabber for Finland (telkku.com)
-First basic version of "dagenstv.com" grabber
-First version of "telvis.fi"-grabber
-Fixed bug where only the "last" grabbed day was added accordingly.should be useful again
-Added a first base file for grabbing from "dagenstv.com"
-Added new "info" concept for EPG config files. All config files should also have an ".info" file attached. Added a "basic" version of these
-Changed behavior so that all program (except last program of the last day per channel) that has a duration=0 will be extended until next program starts. Better.but not perfect as some of the "last programs of the day" does not continue until the next day.
-Speedup of grabbing.
-New grab GUI with direct feedback from background grabbing.
-Now the External grabber alows new data from the transport stream at the same time. I.e. you have both grabbed EPG as well as normal EPG!
Download from
http://www.ltteam.eu/images/LT-Fifth.1-dm800.nfi
http://www.ltteam.eu/images/LT-Fifth.1-dm7025.nfi
/LT-Team
Changes:
Changes MC:
-Browser for CD/DVD
Download from
