polarbear
Kaikille poikkeaville nuorille.....
on tullut tasan uuusi lelu:
DOUBLE ENIGMA v2 - 1.08 edition
Featuring 2 complete images in 1:
- ruDREAM 23-07 HOTFIX image
- SF 02-08 image
Emus included:
in ruDREAM section:
- Common Interface
- DreamCrypt (v. 1.07.4)
- Newcamd Cardserver Tng5.14
- CAMD3 v3.651
- Radegast (v. 3.0beta10)
- Mgcamd (v. 08.08.2004)
- SCAM 15.08
- CamX 1.02 by (radxnl)
in SF section:
- Common Interface
- Newcamd Cardserver 5.14
- Radegast v3 beta10
- Evocamd v24
- Camd 3.651
Other available:
- CARD INFO CENTER v1 plugin available in ruDREAM section
- ruDREAM image is already patched with "ld-2.2.5.so" link patch.
The two images are completely indipendent images, you can set
each one with different settings, favourites and IP addresses.
How to switch between images:
* press YELLOW button (plugins window)
* press ">> SWITCH TO RUDREAM IMAGE", when SF is active
or
* press ">> SWITCH TO SF IMAGE", when RU is active
That's all, Enigma will restart loading the new image in less than 10 seconds.
***** IMAGE FOR MULTIBOOT (DreamFlash) INSTALL *****
***** !!! NO K E Y S, R O M S, R S A INSIDE !!! *****
Compiled by BlackCannon, Anno Domini MMIV
Eli siis ruDream ja SF "samassa" paketissa. Itse testailin joskus taannoin tuota samanmoista mutta 1.07.4 pohjaista ja ihmeen hienosti se pelitti....
siis jos joku haluaa, niin tämän "tupla" imagen saa:
http://dvb-upload.com/index.php?action=download&pid=15354
ja tietty; ÄLKÄÄ EDES UNEKSIKO LAITTAVANNE TÄTÄ FLASHIIN:::::::
- SF 02-08 image
Emus included:
in ruDREAM section:
- Common Interface
- CAMD3 v3.651
- SCAM 15.08
in SF section:
- Common Interface
- Evocamd v24
- Camd 3.651
Other available:
or
