polarbear
Jälleen uusi PP .
pp108_r_28072004
- Based on Enigma of 23.07.2004 (mod)
- Kernel 2.6.5 #36
- Module 1.08
- Auto Subtitle with Bullz Text 0.17
- Recording with subtitles
- Timeshifting
- Autorestore on Flasherase
- Built in language pack (nor, swe, dk)
- Web Interface: 1.4.0
- Support for DreamFlash 1.4
- Emus
- NewCamd + Cardserver 5.11
- Scam 26.07
- Dreamcrypt 1.4
- Plugins
- MultiView 2.1 (Red button)
- Satellites update
- Tuxbox Commander
- Picture viewer
- Jukebox
- BlueButton
- Subtitling :
- Change subtitle to nor, swe, den, fin, eng (default nor) (blue button)
- Change subtitle background
- Change subtitle font (bold, medium or light)
- ***Update
- Restart Newcamd
- Mount / UMount CD-Rom
- Extra Functions (dream->configuration)
- Download Plugins
- Backup/Restore (Alot of different ways to backup/restore)
- HDD Service menu
- Set standby timeout
- Set acoustick
- Set piomode
- Enable 32bit
- Useing DMA
- Set swap HDD (user defined size)
- Set swap USB (user defined size)
- Hdd info
- Expert menu
- Use var folder from HDD/USB or flash
- Format USB
- Sysinfo
- LAN Network configured trough DHCP
Change button funtion:
- BLUE button - BullzText / ***update
- YELLOW button - plugins list
- AUDIO button - sound stream & mode select
- TEXT button - video text
- RED button - EPG List for current channel (Enigma or MultiEPG)
- RED button - double click Multi EPG/MultiView EPG
Known issues:
*) If you your dream crashes try to enable 32mb swapfile on USB/HDD that should do the trick.
When using pictureview your do need the swap file
*) For use of Multiview EPG you have to have a active internet connection.
ai niin, vaikka tuolta:
http://www.dreambox.info/attachment.php?attachmentid=8495&sid=
pp108_r_28072004
- Kernel 2.6.5 #36
- Module 1.08
- Timeshifting
- Emus
- Scam 26.07
- Dreamcrypt 1.4
- Plugins
- Satellites update
- Tuxbox Commander
- Picture viewer
- Jukebox
- BlueButton
- Subtitling :
- ***Update
- Restart Newcamd
- Download Plugins
- HDD Service menu
- Set acoustick
- Set piomode
- Enable 32bit
- Useing DMA
- Hdd info
- Expert menu
- Format USB
- Sysinfo
Known issues:
