- Deskmini X600 + 3 * Nvidia Shield + Synology NAS DS218+ 2 * LG 77" + Genelec + WiiM Pro Plus & Mini + Adam T5V + T7V + T10S - ArcoLinux
Hydra7000 Achilles 1.08
Hydran uusin 1.08.0 tuotos on nimeltään Achilles, ladattavissa osoitteesta http://www.dreambox.net.au/firmware.php
Ja ensivaikutelma on erittäin hyvä, en ole kokenut mitään ongelmia, softcam-käytössä itselläni Radegast beta12.
Ja ne speksit:
Original DM7000 1.08 image by The_Hydra
- 1.08 kernel (2.6.5)
- 1.08.1 enigma (2004.09.02)
- Radegast [v3.0 beta12]
- Newcamd [v5.17]
- DreamCrypt [v 1.08.1]
- NetPilot advance (v3.0 beta12 (c)2004 The_Hydra/Team Radegast.)
- autosatxml v1.5
- rdgdedit v1.7 (Radegast Edit Plugin by The_Hydra. Invoked from Sm@rtCAM - blue button.)
- scamedit v1.0 (SCAM Edit Plugin by The_Hydra. Edits SCAM config and key files. Invoked from Sm@rtCAM - blue button.)
- NSListing v1.0 (Netstat Plugin by The_Hydra.)
- PSListing v1.0 (Process list Plugin by The_Hydra.)
- Netpilot ConnectView v1.0 (lists netpilot connections The_Hydra.)
- Sm@rtCAM v1.1 (With channel/provider "sticky" support by The_Hydra.)
To invoke rdgdedit or scamedit press ok on the softCAM in the list field.)
- Control Panel v1.6 (To customise just edit /var/etc/cpanel.xml. Invoked by green button.)
- Plugins now invoked by yellow button.
- BusyBox v1.00-pre8 (2004.07.11-08:37+0000)
- Modified Simple and Stylish skin with crypt icons and active SoftCam in OSD.
- OSD supports Green Button - C-Panel, Yellow Button - Plugins, Blue Button - Sm@rtCAM
- SNR meter added to the OSD
- Internet images updates
- Working DHCP support
- bullz_text ready - C-Panel has bullz menu. Thanks to bullz
- Ability to move the whole /var directory to USB or HDD
- Games ready - libfx library now bundled with image
Downloadable addons:
Bullz_text v0.22
DreamBox Weather Forecast v.1.3
DreamFlash v1.5
DreamNetcast Plugin v1.0
DrTic v1.8
Jukebox Plugin v0.4
MultiView - EPG vB2.1
Picviewer Plugin v0.9
rss Reader v1.1
Samba
Shell_tool v0.9
SysInfo Plugin v0.4
Tuxcom Plugin v1.3
Downloadable softCAMS:
- CAMD3 v3.645
- CAMX v1.03
- CS_CLNT v1.13(canal+nl_premiere)
- EVOCAMD v2.6
- MGCAMD v 29.07.2004
- SCAM v21.06
- SCAM v31.08
- XCAMD v2.0
Downloadable languages:
- Czech
- Danish
- Deutsch
- Dutch
- Finnish
- French
- Greek
- Hungarian
- Italian
- Norwegian
- Polish
- Portuguese
- Romanian
- Russian
- Slovak
- Spanish
- Swedish
- Turkish
Downloadable settings:
- Pet123 Settings (Now automatically reloads the settings into the Dreambox)
Fixes / New Features:
- DreamFlash / FlashWizard fix
- Cardspider now runs ok
- PID bug fixed - thx to _NiL_
- Addons /var can now be moved to HSS or USB
- New OSD changes for green, yellow, blue buttons (see above)
- rdgdedit now invoked from Sm@rtCAM by pressing ok button while radegast is selected in list.
- New scamedit invoked from Sm@rtCAM to edit SCAM files. Press ok button while SCAM is selected in list
- Fixed stick/unstick to now look for channel--->provider--->default softCAM. Was a bug in previous
release where order was provider--->channel--->default softCAM.
Known Issues:
- None
Sm@rtCAM:
This image does not contain any keys or rom files. It is up to the enduser to add them should he wish to use this image other than with a legal subscription card. The Hydra team is not responsible for any unauthorised use of this firmware.
Please flash erase this image after you install it:
As booting up your Dreambox HOLD IN the UP ARROW button on the box until the message "Flash Erase" appears
on your LCD
Failure to do this may give an error message "Cannot Parse /var/etc/cpanel.xml"
Many thanks from The_Hydra....
Ja ne speksit:
- Newcamd [v5.17]
- autosatxml v1.5
Bullz_text v0.22
DreamFlash v1.5
DrTic v1.8
Jukebox Plugin v0.4
rss Reader v1.1
Samba
Shell_tool v0.9
SysInfo Plugin v0.4
Tuxcom Plugin v1.3
- CAMD3 v3.645
- CAMX v1.03
- EVOCAMD v2.6
- SCAM v21.06
- SCAM v31.08
- XCAMD v2.0
- Czech
- Danish
- Deutsch
- Dutch
- Finnish
- French
- Greek
- Hungarian
- Italian
- Norwegian
- Polish
- Portuguese
- Romanian
- Russian
- Slovak
- Spanish
- Swedish
- Turkish
Known Issues:
- None
Sm@rtCAM:
on your LCD
