Humax PVR-8000T ohjelmistopäivitys 14.12.04.
Vihdoinkin se tuli. Parannusten lista (alla) näyttää myös hyvältä.
Sitten kun joku viitsisi suomentaa nuo ohjeet oikeanlaisen kaapelin tekoa varten.. ?.
http://www.humaxdigital.com (päivityssivuille tosin pitää rekisteröityä).
Addition to the record function; You can now record Radio programmes.
Improvement to the instant record function; You can now select different lengths of recording time by pressing the Instant record button multiple times:
30 mins
1 hours
2 hours
3 hours +
Improvement to the instant record function; While recording is in progress you can extend the time by pressing the Instant record button.
Accessing the EPG Guide While recording is in progress it is now possible to access the Guide allowing you to view or reserve.
Deleting Recordings The Default PROTECT option has now been change to DISABLED.
Reserving recordings It is now possible to overlap recordings. You can now set the same time for the end time of one recording and the start time of a second recording.
Reserving Daily/Weekly recordings For Daily/Weekly recordings the Dates are now displayed correctly.
It is now possible to record programmes next year as the Year Date is now recognized correctly.
16:9 Display problem Both Menu and Guide are displayed correctly.
Favourite Lists Radio channels are now displayed correctly in the Favourites lists.
TP information The TP information is now displayed when searching for channels.
Dual Mono function support. Audio language descriptor: if 2 different languages are available they are saved as Left & Right in Flash Memory.
SPDIF output Improved the SPDIF output control.
30 mins
1 hours
2 hours
3 hours +
