Gemini2 v3.9 800 & 8000
Gemini2 v3.9:
* Engima from: 29.11.2008
* Busybox 1.0.1
* Tuxtxt 1.95
* long BLUE -> PiP (DM7025)
* RED - Record
* Yellow - Timeshift
Addons:
Camd:
* Assign different Camds to Stations/Providers (AutoCam).
Daemon / Server / Clients:
* Upnp Server / Client
Infobar / OSD:
* HD-Skin preinstalled (DM80..)
* Provider and Satellite will be shown in the Infobar (depending on the skin).
* Show Onlinestatus when the Box is connected to the Internet (has to be activated in the BP -> Extras/Settings/Online)
* HDTV-Logo in the Infobar (DM80..)
Files / Devices:
* Device Manager (format, mount and other functions)
* Hotplug for USB-Devices (are shown in the OSD - Can be mounted using the Device-Manager)
EPG:
* EPG-autosave- Saves the EPG data at a defined time
* Duration of current Event in the programm overview ( BP -> Info -> EPG)
Extra:
* Dreamnetcast (shoutcast-player) with Streamripper (direct recording from server and coding into mp3s).
* Alarm clock(plays mp3s at a fixed time)
* System Info: Many extra receiver infos like stream-rates, kernel-, memory- and processinfos.
* EPG Cache and EPG Refresh (updates the EPG at the night) adjustable over BP.
* overview of the different Scrambling systems that the current station uses.
* Quickbutton
* Summary of the HDTV-Channels in the Channellist->Satellites (DM80..)
* customization for the 8000, partly internal
* Jukebox, Soundplayer supports MP3, OGG, FLAC and WAV. With Playlist-organizer and display of the cover. It's insignificant where the image is placed (Soundfile or in the same folder) It's still beta, same new functions will be added with the next image...
Fix + Updates:
* RSS reader with title images and new XML
* Webcam-Viewer cataloged in sub folders and new XML
* folder for Autofs changed. (customization at DMM's Autofs-System). New folder is "/autofs", config-file is "/etc/auto.hotplug". Editor in the BP can be used further on.
* Network Hardware added to the Devices Manager
* see CVS
and won't be supported!
