Gemini2 3.2 on julkaistu
timoj
Gemini2 v3.20:
* Engima from: 18.12.2007
* GCC 4.1.1 Original CVS
* Kernel 2.6.12.6
* Busybox 1.0.1
* Tuxtxt 1.95
* CIFS 1.44
* long BLUE -> PiP
* RED - Record
* GREEN - Subservices
* Yellow - Timeshift
Addons:
* Downloading and installation of additional features via internet from Gemini server.
Camd:
Daemon / Server / Clients:
* Upnp Server / Client
Infobar / OSD:
* Showing Onlinestatus when the Box is connected to the Internet (must be activated in the BP -> Extras/Settings/Online)
Files / Devices:
* Support for CDROM/DVD no matter ift it is IDE ur USB
Extra:
* Password can be changed over the menu.
* overwiev of the different Cryptingsystems the actual station uses.
Fix + Updates:
* eMail-Checker extended with SSL support (Overview of your POP3 or IMAP accounts)
* see CVS
and won't be supported!
Download via Database
timoj
