Gemini2 1.80 7025
  • Viestiketjun aloittaja PNP
Gemini2 1.80 7025
Gemini2 v1.80:
* Engima from: 25.08.2006
* GCC 4.1.0 Original CVS
* Busybox 1.01
* Kernel 2.6.12.6
* RED - Record
* GREEN - Subservices
* Display of CaIDs via Infobar
* Password can be changed via menu
* Autocamd
* camd scricpt can be edited
* HDD performance
* Weather Plugin with 10 days forecast
* RSS/RDF reader with TOP list from RSS-scout
* Active PiP
* Blue Button with following functions: 1 x (short) Blue Panel, 2 x (short) Blue Panel -> Extras/Settings, 1 x (long) blue PiP
* The image does now contain a useraddon.xml in /etc to enter an own addon server which will additionally be displayed in download menu. The file actually contains a example.
* Nemesis skins
* IPK can be choosen and installed via browser
* Installation of plugins without Enigma restart
* Settings of Infobar enhanced
* Picon integrated in Gemini (the PNG file must have the same name as the channel) -> Installation of Picicons via Blue Panel
* True automount, examples in /etc/automount.conf. Devices, NFS or CIFS get mounted automatically and also erased if they are not in use for longer than 2 minutes (only working if the kernel of Gemini 1.8 is in use)
* Reach calendar via alarm clock and menu button
* MHW epg activated
* Satpositions on infobar (switchable)
and won't be supported!
Download via Database
http://www.i-have-a-dreambox.com/wbb2/database.php
http://www.dreamboxworld.com
BitchX
kanta-häme
Dreambox 900 4K,Nvidia Shields Android Tv,Apple Tv4,Triax 110,Dreamstar Iptv box
