Gemini v4.30 (dm7000/500plus/56xx/7020/dm500/600pvr))
Gemini v4.3:
* Enigma of: 16.02.2008
* GCC 3.4.4 Original CVS
* Web Interface: 6.0.4-Expert
* Busybox 1.01
* Tuxtxt V1.99
* CIFS 1.44
Remotecontrol:
* 2x RED - EPG style menu
* GREEN - subservices
Addons:
Camd:
Daemon / Server / Clients:
Files / Devices
* Support for OGG/Vorbis
* Random function for MP3 and OGG/Vorbis
* Backup function
* support for the bigger remotecontrol on 500 and 500+ (normaly shipped with 70XX/600pvr - activate on BP->Extras/Settings)
Extras:
* RSS und Weather Plugin (for 7000 and 500 you have to install it)
* System Info: Many extra box infos like HDD temprature, stream-rates (>=7000) or kernel-, memory- and prozessinfos.
* Search EPG of all channels for an Event or a String and set timers directly (press MENU in EPG window or go to BP -> Extras)
* EPG-Infos of all recorded movies can be showed without starting the record.
* disable the TV - output while taking a recording, streaming a movie and manually (usefull for boxes with very low lan-speed)
* update system time via transponder or internet ( Protocol RFC868 )
* EPG-Refresh Based on Enigma-Timers (BP->Extras, Beta)
* In the Information menu own matrix for network Devices
* create own weather.xml for your Country in RSS/Weather Addon
* Dreamnetcast now with Favorites administration
Fix + update:
* eMail-Checker und IMAP (Unread e-mails remain unread, problems with GMail)
* Pictures turn lasts only half as long, all formats ca now be rotated (rotate with < 0 > on your Remote Control)
* please see CVS
Interfaces WebIF:
http://127.0.0.1/cgi-bin/setKey?typ=STR&.test&val=blabla
http://127.0.0.1/cgi-bin/getKey?typ=INT&.itedvb/int-test
Recommendation:
http://www.dreamboxworld.com/dbw/main.htm
Gemini v4.3:
* Busybox 1.01
* Tuxtxt V1.99
* CIFS 1.44
Remotecontrol:
Addons:
Camd:
Files / Devices
* Backup function
Extras:
Fix + update:
* please see CVS
Interfaces WebIF:
Recommendation:
