Gemini v4.00 (dm500/600pvr)
crashi
Gemini v4.00:
* Enigma of: 24.08.2007
* GCC 3.4.4 Original CVS
* Web Interface: 6.0.2-Expert
* Busybox 1.01
* Tuxtxt V1.99
* CIFS 1.44
Remotecontrol:
* 2x RED - EPG style menu
* GREEN - subservices
Addons:
Camd:
Daemon / Server / Clients:
Files / Devices
* Support for OGG/Vorbis
* Backup function
Extras:
* Search EPG of all channels for an Event or a String and set timers directly (press MENU in EPG window or go to BP -> Extras)
* EPG-Infos of all recorded movies can be showed without starting the record.
* Infoszeile im Sendermenü jetzt wie in Enigma2.
* Infobar in the channelmenu is now like in E2.
* Changed the addon routines. There will be a preview available by many addons and skins (due to the new structure of the addons we also did the version jump)
* own RSS und Weather Plugin (for 7000 and 500 you have to install it)
* disable the TV-out (scart out) while you take a record (onle makes sense with the 500)
* Completely reworked DreamNetCast
* ECM-Expert+ now using a separate window
Fix + update:
* see CVS
nterfaces WebIF:
Recommendation:
http://www.dreamboxworld.org/dbw/dm500/Gemini_400_DM500.zip
http://www.dreamboxworld.org/dbw/dm600pvr/gemini-400-dm600pvr-200708280104.nfi.zip
Vihdoinkin näyttää tulleen EPG searchi ja ajastus siitä suoraan.
Harb
Espoo
Kotona: Vu+ Solo 4K (1 x tuplaS2, 1 x tuplaT2), Nvidia Shield Pro, Linux/Kodi, Onkyo TX-NR676E, Raspberry Pi 2, Netgear Orbi ac3000
Mökillä: Xtrend et10000 (2 x S2, 2 x T2), 1 Nvidia Shield, Rapsberry Pi 1, Netgear Orbi ac3000, ASUS 4G-AC55U
TomeriZ
Rovaniemi
Vu+ Uno 4K SE / Samsung 55" 4K
Rascals
Mecool K3 Pro + CoreElec
