Gemini 4.4: 500, 5620, 7000
Gemini v4.4:
* Enigma of: 27.05.2008
* GCC 3.4.4 Original CVS
* Web Interface: 6.0.4-Expert
* Busybox 1.01
* Tuxtxt V1.99
* CIFS 1.44
Remotecontrol:
* 2x RED - EPG style menu
* GREEN - subservices
Addons:
Camd:
Daemon / Server / Clients:
* Automatic test wehter the box is connected with the internet or not (Well be shown in the infobar)
* added editor to configure the cron-daemon
* Little Apache (HTTP-Server based on HTTPD)
* Upnp Client and Server (for DM500/56x0 must be installed from Gemini-Server as addon)
* Settings for syslogd
* NFS-Server (based on the NFS-Kernel-Modules, nor for DM500, DM500+ and DM56xx)
* Moved Gemini events (Ripper, Calendar, email-Checker) from BluePanel Menu into the infobar (eLabel-Name = geminievent)
Files / Devices
* Random function for all kind of soundfiles
* Backup function
* support for the bigger remotecontrol on 500 and 500+ (normaly shipped with 70XX/600pvr - activate on BP->Extras/Settings)
* Support for FLAC, OGG/Vorbis and WAV (please install codecs in the BP)
* Functions for SWAP (virtual memory). Create, delete, size and location.
EPG
* additional functions (e.g. dishnetwork, cache, location)
* search all channels for an event or an own string. Timers can be added immediatly (Press "Menu" in the epg or use use BP -> extras -> EPG-Refresh)
* Infos of the recorded movies can be shown without starting the movie
* refresh EPG using the enigma-timer (BP -> extras - EPG-Refresh)
Extras:
* Dreamnetcast (shoutcast-player) with Streamripper (direct recording from server and coding into mp3´s) (for DM500/56x0 must be installed from Gemini-Server)
* RSS und Weather Plugin (for DM500/56x0/7000 must be installed from Gemini-Server)
* System Info: Many extra box infos like HDD temprature, stream-rates (>=7000) or kernel-, memory- and prozessinfos.
* change the settings for recording (before Time, after-recording time,, location and recover-function)
* Create your own satellites.xml including only the satellites you really need.
* Calendar for iCalendar format + reminder ( Supported by MAC, KDE, Thunderbird, Goole calander, Rainlendar...). Standard folder is /var/etc/ical (for DM500/56x0 must be installed from Gemini-Server)
* eTorrent - a torrent client based on ctorrent. Can be managed completly over the OSD (for DM500/56x0/7000 must be installed from Gemini-Server)
* disable the TV - output while taking a recording, streaming a movie and manually (usefull for boxes with very low lan-speed)
* update system time via transponder or internet ( Protocol RFC868 )
* eMail-Checker extended with SSL support (Overview of your POP3 or IMAP accounts)
* added rotation for all kinds of pictures. Also automatic rotation using EXIF (must be activated in the menu)
* Re-Zapp, sitching back to the actual Service after X-minutes (BP -> Extras -> Re-Zapp)
* Show wehter the box is an original Dreambox or not (using MAC adress, BP -> System -> Dreambox -> Manufacturer)
* Recording into differnt folders (Settings are in the Timer-Menu)
* Flashing LED´s while rcording for boxes without Display can be activated in BP -> Extra -> Recording)
* Autosave for EPG-Cache (BP -> Extra -> EPG-Settings)
* Duration of current Event in the programm overvie ( BP -> Info -> EPG)
* EPG-Refresh Based on Enigma-Timers (BP->Extras, Beta)
* In the Information menu own matrix for network Devices
* create own weather.xml for your Country in RSS/Weather Addon
* generall information of the EPG-Data (BP -> Info -> EPG)
* the period for the EPG-Data can now be changed (BP-Extra->EPG-Settings)
Fix + update:
* changed the routines for rotating pictures. You now can countinue the rotation using the buttons <>
* Fixed the EGP-Display in the overview when using several languages.
* have a look in the CVS
Interfaces WebIF:
http://127.0.0.1/cgi-bin/setKey?typ=STR&.test&val=blabla
http://127.0.0.1/cgi-bin/getKey?typ=INT&.itedvb/int-test
Gemini Images may only be used on receivers of the manufacturer Dream-Multimedia-TV.
The use of this Image is on your own risk.
Recommendation:
if several processes running in background. We assume no liability for direct or indirect damage.
http://www.dreamboxworld.com/dbw/php/index.php
