Gemini 4.10 DM 7000 + löytyy muillekin omansa
Status
chaoscreator
Kemiönsaari
http://www.dreamboxworld.com/dbw/main.htm
Gemini v4.1:
* Enigma of: 23.10.2007
* GCC 3.4.4 Original CVS
* Web Interface: 6.0.4-Expert
* Busybox 1.01
* Tuxtxt V1.99
* CIFS 1.44
Remotecontrol:
* 2x RED - EPG style menu
* GREEN - subservices
Addons:
Camd:
Daemon / Server / Clients:
Files / Devices
* Support for OGG/Vorbis
* Backup function
Extras:
* RSS und Weather Plugin (for 7000 and 500 you have to install it)
* Search EPG of all channels for an Event or a String and set timers directly (press MENU in EPG window or go to BP -> Extras)
* EPG-Infos of all recorded movies can be showed without starting the record.
* disable the TV - output while taking a recording, streaming a movie and manually (usefull for boxes with very low lan-speed)
* added some Gemini plugins to the Quick-Button
* update system time via transponder or internet ( Protocol RFC868 - version is still in BETA.)
* eMail-Checker (Overview of your POP3 or IMAP accounts, deleting mails possible but not reading - version is still in BETA.)
* support for the bigger remotecontrol on 500 and 500+ (normaly shipped with 70XX/600pvr - activate on BP->Extras/Settings)
Fix + update:
* see CVS
* EPG-Fix from DMM (ZDF Transponder)
* EPG-search for cable boxes
* fix 2gb error on etorrent
* Show the total size of the film when it is splited in several TS - files.
Interfaces WebIF:
Recommendation:
Status
