Gemini 3.1: 7020, 7000, 56*0, 500
Gemini v3.10:
* Enigma of: 22.08.2006
* GCC 3.4.4 Original CVS
* Web Interface: 5.9.7-Expert
* Busybox 1.01
* Tuxtxt V1.98
* 2x RED - EPG style menu
* GREEN - subservices
* Download and installation of additional features via Internet from Gemini server
* System Info: Many extra box infos (for example harddisk-temperature or all Enigma settings)
* Support for OGG/Vorbis
* smbmount
* Support for CDROM/DVD, no matter if IDE or USB (>=7000 )
* Record CIFS/NFS: Record to a CIFS or NFS mounted harddisk (only working without internal hard drive, mountpoint set to "var/mnt/hdd" and at least 3GB disk space)
* Extra menu: Settings for many features like Inadyn, HTTPD, EPG-Cache, "/var" swap-out and many more
* Backup function
* Background pictures for Radio, MP3 and SCAN can be changed via Blue Panel
* Calender including reminder (can be changed via
.../calendar.conf)
* EPG for Dishnetwork
* 2 new root entries for music and pictures can be created in the filemenu
(BP->Extras/Settings->Root-Entry)
* Alarm clock with volume offset adjustable
playing your own WAV-files.
* Display of current channel stream rates ( >=7000)
* cifs-1.42b
* Multisocket second camd socket (cam1.socket) switchable.
* Register an own addon server( useraddon.xml)
* Provider, Frequency, symbol rate and FEC displayed on infobar (dependent on skin)
* Picon integrated in Gemini (the PNG file must have the same name as the channel) -> Installation of Picicons via Blue Panel
* True automount, examples in var/etc/automount.conf. Devices get mounted automatically and also erased if they are not in use for longer than 2 minutes
(only working if the kernel of Gemini 3.1 is in use)
Fix:
* Dreamnetcast revised
* Multisocket support for more camd's
* attend cvs
Interfaces WebIF:
This images doesn't contain any keys or softcams. Backups or other modified Images are not from us and won't be supported!
Recommendation:
Download via Database
  • Generation07-09_Gem31.rar
    119.9 KB · Lukukerrat: 39
    57.5 KB · Lukukerrat: 513
    56.7 KB · Lukukerrat: 504
mphumax
Tampere
Octagon sf4008 s2x
Triax TD-110 +moteck sg-2100A
Octagon sx88
DrHD F15
Mystique SaTiX-S2 Sky V2 USB
mphumax
Tampere
Octagon sf4008 s2x
Octagon sx88
DrHD F15
mphumax
Tampere
Octagon sf4008 s2x
Octagon sx88
DrHD F15
