Gemini 3.00: DB7000
Gemini 3.00: DB7000
Gemini v3.00:
* Enigma of: 21.06.2006
* GCC 3.4.4 Original CVS
* Web Interface: 5.9.7-Expert
* Busybox 1.01
* Tuxtxt V1.98
* 2x RED - EPG style menu
* GREEN - subservices
* Downloading and installation of additional features via Internet from Gemini server
* System Info: Many extra box infos (for example harddisk-temperature or all Enigma-settings)
* Download of Gemini news in background
* Support for OGG/Vorbis
* smbmount
* Support for CDROM/DVD, no matter if IDE or USB port ( >=7000 )
* Record CIFS/NFS: Record to a CIFS or NFS mounted harddisk (only working if there is no harddisk inside,
mountpoint set to "/mnt/usb" and at least 3GB disk space)
* Extra Menu: Settings for many extras like Inadyn, HTTPD, EPG-Cache, swap-out of "/var" and many more
* Backup function
* Background pictures for Radio, MP3 and SCAN can be changed via Blue Panel
* Calender including reminder (can be changed via .../gemini_cal.conf)
* EPG for Dishnetwork
* Dreambox can be used as printserver(BP->Extras/Settings->Printer (LPD), FAQ can be found in the database
* Alarm clock with volume offset adjustable playing your own WAV-files.
* Display of current channel stream rates ( >=7000 )
* cifs-1.42b
* The image does now contain a useraddon.xml in /etc ml for 7020, /var/tuxbox/config for 500 to 7000 to enter an own addon server
which will be additionally displayed in BluePanel -> Addons -> Download. The file actually contains a example.
* multisocket second camd socket (cam1.socket) switchable.
Fix:
* New drivers rel1.10 (=7000)
* Attend CVS
Interfaces WebIF:
We'd like to thank everybody who paricipated in the "Gemini suggestion" thread.
Unfortunatly many things can not be realized from our side.
and won't be supported!
Recommendation:
If you don't install the Image in flash memory, the flash image shouldn't be of a old version.
A swap file/partition (>= 16MB) should be present if several processes running in background.
http://www.dreamboxworld.com/dbw/main.htm
BMW
Lapland
  • Bullz_Text_0.42.rar
    51 KB · Lukukerrat: 12
jpkokko
Hollola
jpkokko
Hollola
jpkokko
Hollola
jpkokko
Hollola
jpkokko
Hollola
