Gemini 2 for 7025 v3.5
tpautu
Gemini2 v3.5:
* Engima from: 18.05.2008
* Busybox 1.0.1
* Tuxtxt 1.95
* long BLUE -> PiP
* RED - Record
* Yellow - Timeshift
Addons:
Camd:
Daemon / Server / Clients:
* Upnp Server / Client
Infobar / OSD:
* Show Onlinestatus when the Box is connected to the Internet (must be activated in the BP -> Extras/Settings/Online)
Files / Devices:
EPG:
* EPG-autosav- Saves the EPG data in a defined time
Extra:
* overwiev of the different Cryptingsystems which the actual station uses.
* Quickbutton
* Duration of current Event in the programm overvie ( BP -> Info -> EPG)
Fix + Updates:
*Adjustments for DM800
* see CVS
and won't be supported!
Download via Database
timoj
tappari
Vantaa
Antenniverkko:
Duo2
Duo 4K SE
Uno 4K SE
Ultimo 4K
Satelliitti:
Ultimo 4K
tappari
Vantaa
Antenniverkko:
Duo2
Duo 4K SE
Uno 4K SE
Ultimo 4K
Satelliitti:
Ultimo 4K
timoj
timoj
timoj
timoj
timoj
