polarbear
Flashwizard 4.0 Pro...
Nyt sitä saa:
first public release of FW 4.0 PRO
New Features:
- FlashWizard PRO is now a standalone program: you don’t need to install DreamFlash for having images on multiboot. FlashWizard PRO installs multiboot images on /mnt/usb/fwpro/ and /hdd/fwpro/
- ONLY 40K required space on flash image. So, more space free for our emus, plugins and settings... ;-)
- Installs images on Usb Stick and/or Hard Disk, even used together:
the installed images will be automatically recognized at boot time, then loaded from their install devices.
Up to 100 images allowed, both on hdd or usb stick.
- Allow Boot Logo display (the starting picture) also for multiboot images.
To use this feature, you need >= 1.08 image in flash.
- Has his own 256 colors boot menu shown at boot time.
Select an image and press OK to load it: the boot logo (if available) will be displayed.
- Automatically checks and installs his boot menu on flash image (even if you are actually running a multiboot image).
- Activates the VCR SCART output at boot time, allowing display of the boot menu also through the devices connected to it (i. e. a video-sender connected to VCR out)
- FLASH install:
FlashWizard PRO performs a check (verify) of the data written to the flash memory while installing an image (or restoring a flash backup), to make sure the install will come out without errors.
If a data block went bad in writing, FlashWizard PRO automatically rewrite it to flash, until it is stored without errors.
- Widely improved the backup/restore procedure, much more speed up the archiving phase.
http://www.satnews.it/ricevitori/dreambox/software/FLASHWIZARD_PRO_4.0.zip
Nyt sitä saa:
New Features:
- FLASH install:
