EDG PerfectFlashDualboot CVSplus 01.08.2006
crashi
EDG PerfectFlashDualboot CVSplus 01.08.2006 (7000s musicbob)
The first DM7000 image dual boot:
rel 1_1_0 - rel 1_09_1d !!!
Linux version 2.6.9 (tux@ubuntu) (gcc version 3.4.4) #1 Mon Jul 31 22:47:32 CEST 2006
Enigma: CVS 01.08.2006
Firmware:
* Dual Release
* release 1.1.0 Modules: 1.1.0
* release 1.09.1d Modules: 1.09.1d
Web Interface: 5.9.7-Expert
Private Epg enabled
TuxTxt: 1.98
Satellites XML lyngsat 01.07
Full italian translation by EDG
pmt.tmp present
/var/bin/userstart.sh included
FLASHWIZARD REMOTE plugin included!
NO EMUS NO KEYS INCLUDED
(ENG)
With this image it is possible to choose which o.s. version to boot, between rel1.09.1d and rel1.1.0
You can select the o.s. version through a plugin, then reboot dreambox to let it boot with the choosen version.
It is the absolutely first DM7000 image which allow to select release version without reflashing dreambox!
For the above reason, it is full compatible with all the most recent images, as you can boot as 1.09.1d or 1.1.0 from this flash image.
This image is useful for FLASH, as you can select o.s. version only if it is installed in FLASH (multiboot images will start with selected flash o.s. version).
While booting, the choosen o.s. version will be displayed both on TV screen and LCD display (1.09.1d or 1.1.0).
http://www.dreamboxonline.com/forums/index.php
http://www.dreamboxonline.com/einstein_7000.htm
