EDG-Nemesis 3.x (DM70x0,DM500(+),DM56x,DM600pvr)
crashi
EDG-Nemesis 3.2(DM70x0,DM500(+),DM56x0,DM600pvr)
* Enigma of: 23.10.2007
* New driver (head.ko) 22-10-2007
* Linux version 2.6.9
* GCC 3.4.4 Original CVS 1.1.0
* Web Interface: 6.0.4-Expert
* Busybox 1.01
* Tuxtxt v. 1.99
* for use in flash or MB (via NFS, USB, HDD or CF)
* BLUE - Nemesis Panel
* BLUE > 1s - ECM INFO, EMM INFO e PID INFO
* 2x BLUE - Addons
* YELLOW – Plugins
* YELLOW > 1s – *** - CS Info
* GREEN – subservices
* GREEN > 1s – EPG Control Center
* 2x RED - EPG style menu(Included epgui, MvEPG, WeekEPG you do install it to activate a function)
* Nemesis *** Manager 3.0.0
* Nemesis Web-If *** Manager
* Nemesis *** Manager in italian & English
* Independent Start & Stop *** / CARDSERVER
* Advanced Inadyn service configuration, with log manager
* Swap file supported in (HDD CF or USB)
* Path manager panel
- Setting PVR Movie folder
- Setting Picon folder
* Iptables/Firewall Panel
- Start/Stop firewall
- Firewall configuration
- You can add/remove yours rules directly from panel
* Picon support included in Enigma
- You do install only Picon Images from blue Panel
- You can install Picon images in FLASH
* Syslog panel
- Start/Stop syslog daemon
- Syslog configuration
- Debugging enigma directly to syslog, no reboot needed.
* EPG Control Center Panel
- You can download and store, manually or scheduled, EPG data for:
- Enigma EPG Cache
- MvEPG
- WeekEPG
- EpGUI
- Please install the plugin only from EDG-Nemesis addons by blue panel
- You can find a guide in our forum
* Autostandby/autoshutdown (to manage a unwanted reboot)
* Advanced external programs control
* Can start / stop your own binary by panel (see /var/etc/sample_startup.sh)
* Can create your own autostart boot script (see /var/etc/sample_startup.sh)
* Support for gSUB via advanced external programs control
* Advanced User Script
* Can run script in kernel mode
* Autofs (see /etc/auto.net)
* Crond (see http://www.dreamboxonline.com/forums...11&postcount=6 for guide)
* Automount (see /var/script/mount.sh)
* Advanced System info (see /var/etc/script.xml)
* Advanced *** info (see /var/etc/emuscript.xml)
* Parental control shortcut
* EDG-Nemesis news
* MediaHighwayEpg
* emm, ecm support
* Support openvpn (please download plugin…)
Display Function:
* New Skin Black-Matrix EDG Nemesis Version By Matrix10
* Skin Lite on Button OK press
* Display Snr, Agc, Ber
* Display video info
* Display frequency, polarization, symbol rate
* Display *** in use
* Display service providers name
* Display CaID, ProvID, PID, ecm time, hops
* Display Decoding Source (you can hide if you want)
* Display DC as IRDETO in OSD
* Display long date format
* Web-if and other graphics content modified (by Server)
Addons:
* Advanced addons Manager
* Internet addons download with Proxy support
* Manual addons install
* Remove installed addons
Misc:
* Support modules for openvpn (tun.ko) included
* Samba Server
* Samba client
* NFS Server
No keys, No *** included
Regards:
- developper and betatester.
- MaxZ4 to support for WeekEPG
- Skin by Matrix10
- Bootlogo and graphics by Server (based on DDAAXX graphics)
SPECIAL THANK’S TO: tension from the special collaboration to developping Epg Control Center
HOME SITE:
http://www.edg-nemesis.tv
HOME FORUM:
http://www.dreamboxonline.com/forums/index.php
Lataukset kuntoon tällä: http://xario.t35.com/extra.url.zip
Purku ja siirto /var/etc hakemistoon.
