DS v3.3 DM7000
DS v3.3 DM7000
Image per FLASH / USB / HDD / CF / NFS
+ CVS 25.08.2007
+ kernel v. 2.6.9 (1.10)
+ enigma v. 1.10 Mod (25.08.2007 mod DS Team)
+ BusyBox v1.01 (2007.06.20-14:09+0000 mod DS Team)
+ Web Interface: 6.02-Expert mod DS
+ Gcc 3.4.4
+ FP Firmware 1.06
+ LZMA Patch
+ ScriptService 2.05 mod DS
... THIS FIRMWARE DOES NOT INCLUDE ****, NOR EMULATORS, NOR URLS FOR DOWNLOADING ILLEGAL STUFFS OF ANY TYPE. ONLY WITH ORGINAL DREAMCRYPT SUPPORT..
... DS IS NOT RESPONSIBLE IN ANY WAY FOR WHAT THE USERS WILL DO WITH THIS FIRMWARE.
NEWS & FIXES in DS 3.3
- Rebuilded Extras
- Move Folder Setup moved to Expert Setup
- All DS Stuff, .emuname, .emunumber, .plugins, .emus ( urls' ), userskin.conf, autostartscripts moved to /var/etc/dsteam
- Added Sin *** Updater in Extended
- added BU **** Updater in Extended
- Removed DVB Snoop Logger ( no need this )
- HDD Accustic and STandby Time Fixed
- HDD Recording Fixed
- HDD PLay Movies Fixed
- Swap File AutoON Fixed
- ScriptService.cfg Fixed
- Finaly Stanby Problem Fixed
- Fixed DS WEb Center - Current emu name
- Fixed libc.so Inadyn
- Optimize Lite Skin
- QuickButton now is under HELP button
- SubServices Fix on Green
- New Default Skin MP3 by Matrix10 .[/b] many thanks
Dreambox CVS Changes:
- added eServiceHandlerExternal implementation; allows to register external media players to files and directories
- added background pixmap support for eProgress and eGauge
- WARNING: renamed current 'pixmap' skin property into 'sliderpixmap'
- 'pixmap' skin property is now used to set the background pixmap (corresponding with how other widgets use the 'pixmap' property)
- had to remove the alphatest member, to keep binary compatibility
(skin 'alphatest' property still works though, 'alphatest' now sets left color to -1)
ITGATE/TECHNOMATE CVS Changes:
- Improved signal sensitivity
- Improved DiSEqC 1.2 compatibility and memory
- Fixed audio track recognition
- Improved picture quality and YPbPr recognition
- PVR multiple audio track recording
- Improved PVR compatibility and functionality
- Improved NTSC compatibility
- Fixed Parental Lock
- Fixed Audio Track saving
- Locks onto a working Audio Track
- Improved MMC mounting compatibility
- Improved Lip synchronisation on live stream and PVR playback
- Improved EPG recognition
- More stable multiboot
- Improved Loop Out functionality
-Disabled scart output in Standby mode
-Improved ethernet data transfer rate
- New Drivers
New mapping of Buttons:
+ BLUE Button - EmuManager
+ YELLOW Button - DS Extras
+ HELP Button - QuickButton
+ GREEN Button - Subservices (NVOD)
+ AUDIO Button - Audio Selection
+ TEXT Button - Videotext
+ RED Button - EPG List for the current channel
+ 2x RED Button - Double Click for EPG Style Menu>at the moment on External EPG Nova and SKY UK shedule(need it internet connection)
ChangeLog:
NEWS & FIXES in DS 3.2
- Show number of (new) services in satellites-menu
- add possibility to remove all "new service"-flags of one satellite in satellites-menu
- Picon Pack on server ( fixed strange words of services )
- Fixed loading picons with stange words
- Fixed support with MV EPG
- moved Dream->Extras to Yellow button and create shortcuts..
- Added "dsProgress" - color progress bars
- Added "eGuage" - from cvs gui to have a moving square ( vlome for example )
- Added little tool to change default Movies Store
- Added Dream NET Cast to Extras
- added ECM Time into Skin
- added Hops into Skin
- added Source into Skin
- added Enable/Disable Ecm Time and Hops in Skin
- added Enable/Disable Source in Skin
- fixed Lite Skin - no more little dissapiring after zap
- added Remember EMU to Bouqet - Stick Emu to Bouqet.
- Fixed CCcam WWW Informations in WWW DS Center (( button on Web Interface )
NEWS & FIXES in DS 3.1
- Added Favorite Plugin to QuickButton Option
- Added Advanced Remote Conrol via Web Interface ( OSD Shot, Screenshot )
- Added DS Style Menu
- Added Skin Preview - We need Screenshots of Our Skins ( USERSKIN and NORMAL to put it into )
- add RASS (Radio Screen Show) support (at moment just used on SWR3, DASDING
and cont.ra.
- add new drivers for dm500 dm7000 dm5620 with support for higher ancillary
data bitrates (needed for rass)..
- Fixed Infobar in File Mode (now it not hangs and works like normall infobar)
- DS WWW Center 0.5
+ Added Status - which emu currently is running
+Added List of installed SoftCams
+ ECM info
+ Current EMU
+ Channel name
- added Internal Icon for channel
- added missing icon logger
- enable/disable making pmt.tmp file so Gbox and CCcam now can work together
- added in EmuManager button: MrSticker.
- now you can link your EMU to channel - Sticky to channel
- removed DishEPG ( no need, it only take place..and do slower enigma )
- Update CVS
- now dsemud is making every emu change /var/tmp/dsemud.info so if someone will make mistake in xml file will know what did bad.
Example dsemud.info files:
Code:
/var/emu_scripts/evocamd.xml - Parse error: not well-formed at line 5
Common Interface mode.
or
Code:
Current emulator: Evocamd
Emudaemon(s)
OK -> /var/bin/evocamd - RUNNING
Plugins:
+ EmuManager 1.11
+ dsemud 1.1.8
+ Advenced EMU configs: Newcamd, Mgcamd, Evocamd, ****
+ TuxTxt 1.96
+ Manager Addons 1.6
+ MHW Support
+ Reiserfs Support
+ Flashtool Expert
+ Private EPG
Infobar Aviable Informations:
+ Active EMU in Skin
+ Active Cryptinfos in Skin
+ SNR & AGC & BERin Skin
+ Provider name in Skin
+ Video Resolution in Skin
+ Fr, SR, Pol, Fec Info in skin
+ Info about from where channel goes, Internal,Cardslot,NET
+ Display Multi-audio and Teletext on OSD
+ Caid in Skin
+ Provider ID in Skin
+ Date in Skin
In Menu->Setup->Expert Setup -> Infobar Setup
+ Infobar Timeout
+ Use Lite Skin
+ Auto Show infobar
+ Show Remaining Time
+ Disable/Enable in Infobar:
- Provider ID
- Ca ID
- Video Resolution
- Date
- Emu Name
- Provider Name
+ Show Sat Position
+ Don't hide Radio Infobar
In Menu->Setup->Expert Setup -> EPG Manager
+ EPG Store Configuration
- USB
- HDD
- CF
+ Enable MHW EPG
+ Enable Dish Network EPG
+ Epg Cache Advanced
+ Enable EPG Messages
- Popop Notice When EPG stream channel found
- Popup Notice Epg downloading in progress
- Popup Notice To not change channel until download completed
- Popup Notice When Epg Download is completed and saved
In Menu->Setup->Expert Setup -> Daemons Setup
- Disable CronD
- Disable DropBear
- Disable OpenVPN
- Disable gSUB
- Disable enigma CHTTPD
- Disable Busybox HTTPD
- Disable SyslogD and KlogD
- Disable TuxMail
In Menu->Setup->Expert Setup -> Decoding Setup
- Disable DsemuD Information on Screen
- Enable Fast zapping
- Auto reconnect cahandler
- Skip confirmations
- Hide error windows
In Menu->Setup->Expert Setup -> QuickButton Configuration
What is that QuickButton Option ??
Now on the Yellow Button You can have what only You will choose from Quick Button Configuration
Aviable options:
+ TV Mode
+ Radio Mode
+ File Mode
+ Plugins List
+ Games List
+ Download Addons
+ Timer
+ Inadyn Setup
+ Sat Find
+ UserMenu
+ System Informations
+ Smarc Script
+ Emu Extended:
- **** File Viewer
- **** File Converter
- **** File Update
In Menu->Extras
+ Downloads Addon
- Internet Update ( plugins, cakes, skins, locales )
- Manual Addon ( /tmp )
- Remove Addon
- Server Url Editor
+ InaDYN Config - DYNDNS Client Advanced Setup
+ DVB Snoop Logger
+ MoviePlayer Setup
+ HTTPD Server Setup
+ gSUB Config
- Free Ram Memory
- Free JFFS2 Memory
- Free Flash Memory
- Free HDD Memory
- Free USB Memory
- Free CF/HDD Memory
- Running Processes
- Active internet Connections
- View and Clear Timer Log
- Harddisk info
- Lan settings info
+ Smart Script
+ User SS Menu
You Can Creat now your own Menus in ScriptService. To create it You need just Edit file in
/var/tuxbox/config/user_ss_menu/usermenu.xml
+ Devices Setup
- HDD Info
-- Current information directly
-- Perform cache read timings
-- Perform device read timings
-- Device Temperature info
-- Updating Device List
- HDD Setup
-- Put Harddisk to start
-- Put Harddisk in standby mode
-- Setup standby timeout
-- Setup acustic
-- Harddrive informations
- USB Settings
--Format usb storage in Auto mode/ DISK / PART1
+ Memory Manager
- Use Swap-File ( HDD, USB, CIFS, NFS, CFS )
- Use for Var folder hdd
- Use for Var folder usb
- Use for Var folder jffs
+ Files Manager
It is nice tool, Here You can moving on Your Dreambox like via FTP, You can Earese, View files. Start binary programs and more...
+ Process Manager
Here You can Kill Your Self any process which are currently running on the Box
+ Startup User Scripts
Here you can add Your 5 own scripts which will run when box will start
+ Satellites.xml Updater
+ MultiMedia Setup
+ Restore / Save Configuration
+ Added "restart enigma" on shutdown menu
+ SAMBA is included
+ REISERFS is included
+ Automount disc/part1 usb stick
+ Autoclean core files on hdd
+ Lan Monitor
+ Stream Manager
+ **** File Viewer
+ **** File Converter
+ **** File Update
+ Nano Editor
+ CD/DVD Supported
+ Advanced Stream Info
+ Nova Week EPG Shedule
+ SKY UK Week EPG Shedule
User Skin
What is this userskin??
User Skin allow You show Your own text on Skin. To turn it on You must turn on Lite Skin ( Menu->Setup->Expert Setup->Infobar Setup ) When Lite is on, and it is hidden, push OK it will show You main Skin, with Your infos . Text which is show in the infobar is takes from
Network Cards:205, Cyfra+ (13E) (S2) Id:3017 xxxxx.dyndns.org(peer) dist:1, No Y/G line
CaID:ECMPid=0B00,0500,0B01,059 5,0B02,058F,0100,0519,1801,057 9
Cs2gbox: OK Peers: OK
Thanks to Sateo, Greg, Matrix10, Nixus, Dingo, Cwispy, Tom0000, ruDream Team, sp69, Juliet Team for their greats SS Menus and their help.
It is up to the enduser to add them should he wish to use this image other than with a legal subscription card.
The DS TEAM is NOT responsible for any unauthorised use of this firmware.
http://www.dreamboxworld.org/dbw/dm7000/ds_7k_3.3_30082007_2245.img.zip
