Ds Team 3.0 Dm7000
Ds Team 3.0 Dm7000
DS TEAM 3.0 for DM7000
Image per FLASH / USB / HDD / CF / NFS
+ CVS 04.03.2007
+ kernel v. 2.6.9 (1.10)
+ enigma v. 1.10 Mod (04.03.2007 mod DS Team)
+ BusyBox v1.01 (2007.02.19-14:09+0000 mod DS Team)
+ Web Interface: 6.02-Expert
+ Gcc 3.4.4
+ FP Firmware 1.06
+ LZMA Patch
+ ScriptService 2.05 mod DS
... THIS FIRMWARE DOES NOT INCLUDE KEYS, NOR EMULATORS, NOR URLS FOR DOWNLOADING ILLEGAL STUFFS OF ANY TYPE. ONLY WITH ORGINAL DREAMCRYPT SUPPORT..
... DS IS NOT RESPONSIBLE IN ANY WAY FOR WHAT THE USERS WILL DO WITH THIS FIRMWARE.
Plugins:
+ EmuManager 1.09
+ dsemud 1.1.0
+ Advenced EMU configs: Newcamd, Mgcamd, Evocamd, ****
+ TuxTxt 1.96
+ Manager Addons 1.6
+ MHW Support
+ Reiserfs Support
+ Flashtool Expert
+ Private EPG
Infobar Aviable Informations:
+ Active EMU in Skin
+ Active Cryptinfos in Skin
+ SNR & AGC & BERin Skin
+ Provider name in Skin
+ Video Resolution in Skin
+ Fr, SR, Pol, Fec Info in skin
+ Info about from where channel goes, Internal,Cardslot,NET
+ Display Multi-audio and Teletext on OSD
+ Caid in Skin
+ Provider ID in Skin
+ Date in Skin
In Menu->Setup->Expert Setup -> Infobar Setup
+ Infobar Timeout
+ Use Lite Skin
+ Auto Show infobar
+ Show Remaining Time
+ Disable/Enable in Infobar:
- Provider ID
- Ca ID
- Video Resolution
- Date
- Emu Name
- Provider Name
+ Show Sat Position
+ Don't hide Radio Infobar
In Menu->Setup->Expert Setup -> EPG Manager
+ EPG Store Configuration
- USB
- HDD
- CF
+ Enable MHW EPG
+ Enable Dish Network EPG
+ Epg Cache Advanced
+ Enable EPG Messages
- Popop Notice When EPG stream channel found
- Popup Notice Epg downloading in progress
- Popup Notice To not change channel until download completed
- Popup Notice When Epg Download is completed and saved
In Menu->Setup->Expert Setup -> Daemons Setup
- Disable CronD
- Disable DropBear
- Disable OpenVPN
- Disable gSUB
- Disable enigma CHTTPD
- Disable Busybox HTTPD
- Disable SyslogD and KlogD
- Disable TuxMail
In Menu->Setup->Expert Setup -> Decoding Setup
- Disable DsemuD Information on Screen
- Enable Fast zapping
- Auto reconnect cahandler
- Skip confirmations
- Hide error windows
In Menu->Setup->Expert Setup -> QuickButton Configuration
What is that QuickButton Option ??
Now on the Yellow Button You can have what only You will choose from Quick Button Configuration
Aviable options:
+ TV Mode
+ Radio Mode
+ File Mode
+ Plugins List
+ Games List
+ Download Addons
+ Timer
+ Inadyn Setup
+ Sat Find
+ UserMenu
+ System Informations
+ Smarc Script
+ Emu Extended:
- **** File Viewer
- **** File Converter
- **** File Update
In Menu->Extras
+ Downloads Addon
- Internet Update ( plugins, cakes, skins, locales )
- Manual Addon ( /tmp )
- Remove Addon
- Server Url Editor
+ InaDYN Config - DYNDNS Client Advanced Setup
+ DVB Snoop Logger
+ MoviePlayer Setup
+ HTTPD Server Setup
+ gSUB Config
- Free Ram Memory
- Free JFFS2 Memory
- Free Flash Memory
- Free HDD Memory
- Free USB Memory
- Free CF/HDD Memory
- Running Processes
- Active internet Connections
- View and Clear Timer Log
- Harddisk info
- Lan settings info
+ Smart Script
+ User SS Menu
You Can Creat now your own Menus in ScriptService. To create it You need just Edit file in
/var/tuxbox/config/user_ss_menu/usermenu.xml
+ Devices Setup
- HDD Info
-- Current information directly
-- Perform cache read timings
-- Perform device read timings
-- Device Temperature info
-- Updating Device List
- HDD Setup
-- Put Harddisk to start
-- Put Harddisk in standby mode
-- Setup standby timeout
-- Setup acustic
-- Harddrive informations
- USB Settings
--Format usb storage in Auto mode/ DISK / PART1
+ Memory Manager
- Use Swap-File ( HDD, USB, CIFS, NFS, CFS )
- Use for Var folder hdd
- Use for Var folder usb
- Use for Var folder jffs
+ Files Manager
It is nice tool, Here You can moving on Your Dreambox like via FTP, You can Earese, View files. Start binary programs and more...
+ Process Manager
Here You can Kill Your Self any process which are currently running on the Box
+ Startup User Scripts
Here you can add Your 5 own scripts which will run when box will start
+ Satellites.xml Updater
+ MultiMedia Setup
+ Restore / Save Configuration
+ Added "restart enigma" on shutdown menu
+ SAMBA is included
+ REISERFS is included
+ Automount disc/part1 usb stick
+ Autoclean core files on hdd
+ Lan Monitor
+ Stream Manager
+ **** File Viewer
+ **** File Converter
+ **** File Update
+ Nano Editor
+ CD/DVD Supported
+ Advanced Stream Info
+ Nova Week EPG Shedule
+ SKY UK Week EPG Shedule
User Skin
What is this userskin??
User Skin allow You show Your own text on Skin. To turn it on You must turn on Lite Skin ( Menu->Setup->Expert Setup->Infobar Setup ) When Lite is on, and it is hidden, push OK it will show You main Skin, with Your infos . Text which is show in the infobar is takes from
sample:
show1 = yes
text1 = /tmp/user_script1.txt
(/tmp/user_script1.txt)
Network Cards:205, Cyfra+ (13E) (S2) Id:3017 xxxxx.dyndns.org(peer) dist:1, No Y/G line
CaID:ECMPid=0B00,0500,0B01,0595,0B02,058F,0100,051 9,1801,0579
Cs2gbox: OK Peers: OK
run_script1 = yes
script1 = /var/bin/user_script.sh 1
if run_script1 = yes
after push OK it is starting script1 = /var/bin/user_script.sh 1
this script will update text in text1 = /tmp/user_script1.txt and show in infobar with new Data
it works so fast
A Config File:
/var/etc/user_skin.conf
Code:
[1] show1 = yes text1 = /tmp/user_script1.txt run_script1 = yes script1 = /var/bin/user_script.sh 1 [2] show2 = yes text2 = /tmp/user_script2.txt run_script2 = no script2 = /var/bin/user_script.sh 2 [3] show3 = yes text3 = /tmp/user_script3.txt run_script3 = no script3 = /var/bin/user_script.sh 3 [4] show4 = yes text4 = /tmp/user_script4.txt run_script4 = yes script4 = /var/bin/user_script.sh 4 [5] show5 = yes text5 = /tmp/user_script5.txt run_script5 = yes script5 = /var/bin/user_script.sh 5 [6] show6 = yes text6 = /tmp/user_script6.txt run_script6 = yes script6 = /var/bin/user_script.sh 6 [7] show7 = yes text7 = /tmp/user_script7.txt run_script7 = yes script7 = /var/bin/user_script.sh 7 [8] show8 = yes text8 = /tmp/user_script8.txt run_script8 = yes script8 = /var/bin/user_script.sh 8 [9] show9 = yes text9 = /tmp/user_script1.txt run_script9 = yes script9 = /var/bin/user_script.sh 1
And in *.esmls
name="USERTEXT%S"
it is dynamic Text Show on Infobar.
show%S = yes/no - show USERTEXT%S on Screen
text%S = /tmp/user_script1.txt - link to file which one will be read to show text from
run_script%S = yes/no - to run script which will update text%S file
script%S = /var/bin/user_script.sh %S link to the script which will be executed
%S = number 1-9
Buttons:
+ BLUE Button - EmuManager
+ YELLOW Button - Quick Button
+ AUDIO Button - Audio Selection
+ TEXT Button - Videotext
+ RED Button - EPG List for the current channel
+ 2x RED Button - Double Click for EPG Style Menu>at the moment on External EPG Nova and SKY UK shedule(need it internet connection)
+ GREEN Button - Subservices (NVOD)
Thanks to Sateo, Greg, Cwispy, Tom0000, ruDream Team, sp69, Matrix10, Juliet Team and Matrix10 for their greats SS Menus and their help.
It is up to the enduser to add them should he wish to use this image other than with a legal subscription card.
The DS TEAM is NOT responsible for any unauthorised use of this firmware.
HOME FORUM:
www.dsteam.cwispy.com
Please report ALL bugs there.
Emu downloads URL:
Send this new_emu.tar.gz to /tmp
Menu->Extras menu->Download Addons->Manual Addon
and done
Your DS Image Team
  • new_emu.tar.gz
    346 tavua · Lukukerrat: 12
